Starting the Vehicle with a Low
Transmitter Battery
If the transmitter battery is weak or if
there is interference with the signal,
the DIC may display NO REMOTE
DETECTED or NO REMOTE KEY
WAS DETECTED PLACE KEY IN
TRANSMITTER POCKET THEN
START YOUR VEHICLE when starting the vehicle.
1. Place the transmitter in the
transmitter pocket/insert.
2. With the vehicle in P (Park) or
N (Neutral)press the brake
pedal and ENGINE
START/STOP.
Replace the transmitter battery
as soon as possible.68a6ed5259c68700ddedb3950ef6dfc6.jpg139d1807252ece6434bb7d2c695276bd.jpg
Sent from my Pixel 2 XL using Tapatalk
  • Thanks 2
1 hour ago, Schmoe said:
Do you have HUD? I was taking a conf call in my truck with the truck turned off (so I was in it longer than normal), and noticed the HUD raises and lowers itself, which sounds a lot like the parking brake sound and (presumably) the fuel pump sound that has been described.
No HUD. I just have a lowly RST. ?
In case you were wondering...  Two bottles of wine fit in the door compartment perfectly!
  • Like 8
  • Haha 5
Not the magnum size bottles :D
So this one is really random... not sure I could even call it a feature.
The construction of the gas fill... valve? neck? filler hole? whatever you call the hole where you put in the gas, is MUCH improved over my 2017.  It's all solid one piece construction.  On my 2017 it was also capless, but there was this stupid plastic screw that can breaking and making the filler hole go all loose, and would cause it to keep shutting off while I was filling gas.
I like the warning screen that comes up reminding me not get distracted and I need to clear it, while driving.....
  • Like 5
  • Haha 6
My recent discovery... In the past week, 3 random people have asked me to show them that "special" tailgate on my Denali. I guess the commercial is working.
Ive never seen that, what causes that message to come up?
I don’t know what triggers it, but it pops up like every couple weeks for me upon startup. Black screen, have to hit OK before you can use anything. Not bad if you catch it before you take off...otherwise like he said, it’s a distraction warning you of distractions. My ‘16 did it too.
Yeah mine comes up every -2-3 weeks too. Wonder if it is triggered by number of days or by number of times pickup is started.
On 4/7/2019 at 9:47 PM, Keta said:
I think the noise is the electric parking brake. Push the button and see if that is the noise you are hearing.
I second this. Wife’s Denali Acadia has the same electronic e-brake and I identified the noise way back when.
Just noticed the LED white  night lighting behind the driver and passenger door handles.
Nice touch.
Not sure if this has already been posted... but the extra anchors in the bed are a nice touch.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
