If you have the HUD with built in Navigation you can obviously display the directions through the HUD.  Unfortunately, if you prefer WAZE for directions you cannot display the WAZE directions through the HUD.  However, if you set up your destination with the built in Nav first you can then go through Android Auto and also set up the destination in WAZE to display on the center digital display.  Basically , you have 2 Navigation's running at the same time.  You have the advantage of the directions showing on the HUD and also getting the traffic, hazards, police updates from WAZE.  On long trips, WAZE has saved me a number of times in avoiding major backups.
Thought I would share a picture of the GMC Tailgate Handle I added to my RST.
  • Like 4
  • Thanks 1
Nice idea. Makes those stake pocket holes obsolete.
Nice!  Where did you get it?  Do you have a part number?
I ordered the handle, bracket and bolts from the GMC Dealer and installed it in 5 minutes. I don’t have the part # but I am sure they can hook you up.54FFA4B5-CA65-4982-AD56-0437AF76FA21.thumb.jpeg.ffc9338caad580fc906fcb4b6193d941.jpeg
  • Thanks 1
Picked up my Trail Boss Thursday and did a road trip to the states Friday. Cool that when you switch the units the speedometer dial and DIC convert to MPH.
Coming from a 2017 F150 and it didn’t do that. Only thing I miss about the F150 is the big gas tank.
Ohhh and I miss the console shift as well.
  • Confused 1
The truck will detect if your trailer's light is malfunctioning and tell you which to check accordingly. Another big this is the truck will automatically engage parking brake if you're loading up the trailer and rock the truck a bit.  I found this out as I was rocking my boat trailer back and forth just a little to get the wheel chock out, as I was doing this I heard the brake on the truck engaging.
Discovered this today.... if you press on the skinny pedal on the right, you can find Ford F-150's in the rear view mirror...
They just appear there... its like magic!
  • Like 13
  • Haha 9
Lol COTD!
On 10/19/2018 at 1:07 PM, sams819 said:
Another small but nice change I noticed. On my 2016 the oil fill was a screw on cap on the valve cover. My 2019 has a filler tube that is high over valve cover and it is level so a funnel sits on it level. Much easier and less messy.  ???
Do you have a picture? I would love to see this.
It actually took me a few seconds...i'm slow today. LMAO.
This also made me sad b/c it reminds me i'm about to drop some money to get the cam phasers replaced on my F-150 so I can get rid of it.
Edited by ChinkySuperman
  • Haha 1
Your parking brake will disengage when you press the gas pedal.
  • Thanks 1
On 7/17/2019 at 10:15 AM, BringTheRain403 said:
Sorry IMO they're all trash. They're annoying AF in stop and go traffic or when you stop at a stop sign for two seconds and it shuts off and turns right back on again and for the 4% fuel mileage savings they say you'll get I'll pass. It's the dumbest feature they've come out with on new vehicles in a long long time...
Sent from my Pixel 2 XL using Tapatalk
agree, mandatory tpms sensors suck too.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
