RE: 2014 - 2018 Silverado/Sierra 1500
Wondering if any one has installed Readylift or Cognito UCA's with their leveling kit. Did you have to cut off the service perches/bump stop? If not have much clearance do you have between the UCA and the stop?
You do cut the droop stop off
