Mine is US built as well, I'm curious now if mine is going to leak. .   I wonder if one supplier was covering both the US and Mexico trucks?  I thought I heard somewhere it was caused by not enough sealant when they were installed but I could be wrong.  I've seen rear windows removed before and it was always just a rubber gasket.
The dealer told me that they had to put a new rear window assembly in because the old one had tiny cracks.  Others have said that was the case with them as well.  I know that the dealership first tried to reseal my window and that didn't work.
My truck is US built.
First attempt at fixing it my dealer removed and re-set the window. I also called GM customer service and got a case number. Still leaked.
Second attempt, my dealer removed the spoiler piece that overhangs the window and re-sealed it. Was told GM would not sign off on a replacement window. Also called GM customer service and had someone assigned to my case. Still leaked.
I sent an e-mail to GM's North American VP explaining my situation. The following day I had a phone call from GM Executive customer service rep. Long story short, my window was finally replaced. The dealer said that they found a hairline crack in my old window.
I just got it back on Saturday. I hope it's finally water tight. Hasn't rained yet though.
Still love the truck but it's been a very frustrating two months that is hopefully behind me.
From February 1st:
Quote
#18-NA-383: Water Found in Rear Interior of Cab, Water Leak at Rear Sliding Window - (Feb 1, 2019)
WINDOW RR-FULL WIDTH, SLIDING, POWER (A48)
Customer may comment on finding water in the rear interior of the cab.
The cause of the condition may be cracking in the rear sliding window plastic upper rail glass guide. The plastic upper rail glass guide may develop small fractures/cracking which allows water to pass through on the glass side of the urethane that attaches to the vehicle body.
Note: The cracks can be in the left and/or right side of the rear sliding window plastic upper rail glass guide which is covered by the roof rear spoiler. Examples of a left (1), then right side (2) visual crack (with the spoiler removed) are shown in the graphics above.
R & R the roof rear spoiler and apply seam sealer to the rear sliding window top encapsulate, following the steps in the Service Procedure below.
Important: When verifying this condition, ensure that the water leak path is due to cracks in the rear sliding window plastic upper rail glass guide, and NOT a leak in the primary urethane seal, between the window and the body.
A leak in the primary urethane seal should be addressed by removing and resealing the window, using the standard service procedure from SI.
That's nice now people have something to print ajd take to the dealer with them. I'm only dealing with the knock sensors and typical lower door and wheel well rust in my 04 Tahoe so far. This all started after 100k miles so I'm still getting along good. No water leaks though. [emoji23][emoji23]
I may have missed it when reading through all posts, but have any solid rear windows been found to leak? my 2014 had the power sliding rear and would have a few drops make their way in center of the sliding section during high pressure washes, but less than 10% of the time. not bad enough to think twice about. I now have a 19 trail boss with the solid rear window and curious if anyone with the same window has found any leaks. Ive had the truck for 2 weeks now and its been far too cold here in ND for any liquid form of h2o ha.
Mine started to leak right after it shattered for some odd reason. Wife and I were heading to dinner, when the rear passenger side glass shattered. No clue why.7b0d9040c9475766649a44448bbe0776.jpgbd43220a257dee7eed69c5fabc26e491.jpgb0181110b67af5f1c14b7b6a40f35408.jpg
Sent from my SM-G973U using Tapatalk
Damn, that sucks. It does happen a lot more than you’d think though. I didn’t know anything about this phenomenon until it happened to my dad’s Cadillac.
 Sometimes a latent defect or chip in the glass from installation will just “go off”. In this case though, I would bet that a poorly fitting frame probably over-stressed the glass in some way. Given the amount of back window issues these trucks have had, hopefully GM will take care of it for you.
Did you read through the thread on exploding rear windows? Sounds the same. https://www.gm-trucks.com/forums/topic/209824-2017-sierra-denali-rear-window-exploded/
On 1/28/2019 at 1:26 PM, GMC-AT said:
You can always go buy a Ford or Dodge since they are perfect and have zero issues... oh wait every 2019 RAM is being recalled now. https://www.detroitnews.com/story/business/autos/chrysler/2019/01/25/ram-1500-power-steering-recall/38955769/
Haha yeah the new Ram 1500's have had great quality control so far:
https://5thgenrams.com/community/threads/water-leaking-in-cab.4877/
"I had a leak in my rear window. took 5 weeks to get a new window replaced. Factory window was missing approx. 8 inches of sealant."
"What's the build date of your truck? I've seen the same issue in reading a few threads, nearly identical 'missing x inches of sealant around the rear window'."
https://5thgenrams.com/community/threads/how-prevalent-are-these-problems.1804/#post-25811
"My leak issues are in the rear and front and involve volumes of of water that totally saturate large areas of carpet. It kinda like buying a flood damaged vehicle. I am embarrassed to show anyone my $60k truck. Its a great truck otherwise but there is no excuse for these issues.....maybe rushed to market TOO soon.
I sent FCA my first "Lemon Law" certified letter today requesting satisfaction within 30 days or by-back. "
I have the 2019 Silverado Trail Boss edition. It is currently in the shop for this repair, it leaked to the point that i ran down the back of the seat, entered the seat back compartment, over filled and ran out in the seat. Almost to water bottles full. I asked the dealer to replace the carpet and rear seat, but they refused on the seat and said the carpet could be replaced, but they would have to pull all the seats and consoles out and he didn't recommend that because panels could get scratched in the process. The way I look at it if there certified people scratch a panel, then they will have to replace it. He said they did the bulletin and applied the sealer because there were no visual cracks, but I think this should be a recall. I told him that I wanted everything documented so that if a mold issue pops up they will have to replace the interior completely. I just can't believe for the amount of money (myself)people are paying for these vehicles that we can't get better quality stuff, or the backing to take care of the issues when they arise. I have been a chevy/GMC supporter for a long time, but it just seems like I end up with issues buying new vehicles that should be flawless.
  • Confused 1
I wonder if these are coming from a certain location as far as where they are built, or a certain build date?
I sprayed mine a bit in the car wash today, didn't seem to leak. Build date of 01/21/19 plant G Silao Mexico :sigh:  I'm going to keep an eye on it first time it rains..
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 252 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
