On 9/8/2019 at 3:47 PM, OnTheReel said:
Sorry and welcome to the club. Unfortunately you’ll have to settle in for at least a couple weeks of BS with your truck.
Are these leaks only happening to LT, LTZ trims with the Sliding Rear windows,  or what about Crew Cab vs Double Cab, any difference there?
Keep something in mind.  I found a leak on my 2015 and it wasn't from the sliding window.  It was actually from the third brake light.  They idiotically use a foam gasket to seal the light when placed into the enclosure of the cab.  I found that the gasket wore out and that was causing water to drip down the headliner over the window and to the back seat.  I pulled their gasket off and replaced it with a better rubber gasket from Home Depot.  This may or may not help some of you, but it's info that I'm hoping will help someone.
Anyone that ha had the rear window replaced have the part number? I’ve got the dealer to agree to replace it but they are asking me which window it is because there are 3 windows, left, right and? I would think it’s one window?
When they replaced mine, per my paperwork, it was part 84569182. Description - Window 16.464 N
On a side note...your dealer doesn't know what window? Seriously? Doesn't exactly inspire confidence.
Edited by fish_guru
more info
My dealer had trouble ordering the window too. It was the first one they had ordered and something about the part numbers made it seem like it was three different pieces. Ultimately they got the right one ordered.
I agree but it was my salesman trying to help me vs. leaving me in the hands of the service department and he knows I can find out information that he doesn't understand. I buy many vehicles from the dealership yearly and my salesman gets me further than the service department does.
Yes, thats what he was saying, 3 windows.
Copy that.
Hope you get it squared away.
Spotted stained headliner on passenger side this week. Build date 11/9/2018.
Going to dealership next Monday. Requested window replacement- will let you all know how it goes.
Just so I know... where is the "hairline" crack generally found? Looks like a plastic part based on images uploaded to this TOPIC..
Window frame? Window track?
Edited by Kozzy
The slider window frame tract.
You probably aren’t going to be able to see them with the spoiler in place. Good luck on getting a new window. Hope you can, but as I understood it, GM isn’t gonna pay for one until after the “gooping“ attempt fails at least once.
  • Sad 1
If you are looking at the rear window from back seat it is above the headrest, more specifically above the end of the plastic tract the window rides in. I was only able to see it once the headliner was pulled down. You might be able to push up on the headliner as far as it will go, you might be able to see it. Mine was easy to find because I just followed the river of water dripping in.
Ok thanks. Did you finally get your window fully replaced? Any leak issues since? @ShamrockShooter
Also- does anyone have a build date as late as mine (11/9/18) that is experiencing this rear window water leak? When I called GM and explained situation and referenced bulletin #18-NA-383.. I was told my truck falls out of the affected date window (10/18).
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
