Nope. Picked it up the same day. Wasn't even that good of a job. I can see the yellow sealant above the window as well. Are the 2020's leaking as well? My confidence in this thing is very low. I'll dump it if I have to keep dealing with this.  Is a new rear window even going to fix this?
Yeah there’s people on here with 20s
I am by no means an expert but from reading this thread seems like the TSB called from Kent High Tech Clear Sealant or equivalent but there was another fella here that had the yellow stuff and it also failed.  Not to say if you got the clear stuff it would have work.  Also don’t know if you live in the salt belt but the sealant needs >16 hours to cure properly in above 50f temps.  And someone here had theorized that maybe the lack of individual seals on all the mounting holes between the spoiler and cab could cause more water to leak in.  There is one long seal that runs along the underneath top edge of the spoiler.  If the tech didn’t tighten the spoiler to the cab, I can see the leak being worse. Of course this doesn’t explain why the non-sliding windows don’t leak.  Lots of info.  Glad this thread exists.
Its back at the dealer this morning. I "encouraged" them to this time follow the TSB and not use what looks like yellow great stuff on it. I am fairly certain that the tech didn't even remove the rear headliner to remove the third break light per the tsb. I told them I didn't want to hear back until the correct tsb was done and the correct sealant has time to set. Probably was a typical rush job as its looks like Chevy is giving the dealer 1.5 hrs to do the work. And now they are having to re do it. I'm sure done correctly it takes longer than that.  I actually use to work at this dealer, its not where I purchased it but its a Chevy problem so the service advisers are not giving me the standard mumbo jumbo. Hopefully its done right this time.
It’d take an hour and half to drop the headliner correctly
There is no "correct" caulk job that will fix this problem. Anyone that says so is lying to you. They caulked my 19 three times and the leak always came back.
Sent from my Pixel 4 using Tapatalk
So it seems that the only real hope is a brand new rear glass assembly.
But even then..
Taking mine in today. Only leaking in two small spots, no headliner damage...yet.
Funny thing is it wont leak with a hose or pressure washer, or sitting on flat ground. It poured last night and it was dry as a bone this morning parked on the street if I park it in my driveway on an incline it leaks.
At what point does GM authorize a new rear window to be installed ? Do they have to do the "caulk" job first ?  Any GM techs on here with any advice?? .. Thanks... Sure would be nice if GM looked at these forums to see what issues their products are having.
Maybe someone should accidentally drive a golf ball thru the glass and let safe lite replace it correctly... IDK at this point.....
My entire glass assembly should be arriving today and the dealer has a glass company they contract out to do the install. They also advised me that the truck will sit indoors after the install for 24 hours before I can pick it up.
Im hoping this resolves the issue but like anything else ill be paranoid and keeping a constant eye on it all the time now
On 2/5/2020 at 11:22 AM, Centrebaseball said:
Someone a long while back mentioned class action discussions with a law firm.  I wonder what became of that?
I looked at one of my rental car invoices while I was driving around waiting for a window - 2 grand! GM is losing their shirt  no on this stuff I would imagine.
I've put on 1200 miles with their loaner car and still going.   They could have just replaced the rear window and been done with this mess.
Seems to me like good dealers who want their customer happy have been finding ways to replace windows and frames which is the correct fix here imo. I have seen very few caulking jobs hold up for people on this website and last, certainly none of them looked professional or something you would expect to get with a dealer warranty fix.
On 2/5/2020 at 12:50 PM, wacnstac said:
Yikes, just bought a 2020 LT trail boss with rear slider without knowing about this issue. Haven't picked up the truck yet (Saturday). Any advice? Should I buy the extended warranty? Is the extended warranty bought at one dealership good at all of them, in case I switch dealers at some point?
Take it for a test spin and go wash it at a car wash with a high pressure washer.  Make sure you spend a few minutes on each corner of the top rear window \ brake light area and see if it leaks.
On 2/5/2020 at 6:10 PM, JohnCasey said:
GM keeps telling me that they want to give me compensation but they can’t tell me what. They only say I have to wait until my truck is repaired and then and only them can they talk about compensation.  Kinda like a health care law. Got to pass it to see what we just voted for
PLEASE reply back and let us know what the compensation is.  I'm going to inquire also.  They told me the same thing about "making it right" and compensation.  They also said that if ti's something that can't be fixed they will look at getting me out of the truck.   I won't count on that but I want an extended warranty after all of the recalls and this window garbage.  With my luck this will fail right at 36,001.
Loop
Yeap will do. Still getting aquanted with the truck at this point and need to read 96 pages of this thread to figure out what the best course of action is o ce I have a leak and the tsb number to refer a dealer to.
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
    • oh ya that's good to know - I would rather use a gear than the brakes down a long hill.  I would not let cruise control take over on snow or towing a trailer for sure on hills anyway.     The other thing about the CO trip was that was all done above 6K feet for the most part, so that has to use more gas as the motor is down a good amount of power up there.   If I drove my 2016 Camaro with a very similar V8 to this 6.6 it would probably get about 23-24 on the fast run up to NE.  But the premium fuel premium is steep here in CO, so it would still only save about $40 in overall costs for the round-trip.  And you sure can't carry much gear in a convertible camaro!
