18 minutes ago, PackerChev said:
Has your new one been leak free?!
3 weeks on FUYAO E4 and leak free so far. However, I went 9 months and 13k miles on the FUYAO E2 before it started leaking.
2 minutes ago, bobboberton1 said:
Is everyone getting replacement glass? Has anyone had an explanation of the repair? My dealer is stating they will reuse the same glass.
The TSB states to caulk the window first. If it re-leaks, replace the window.
Not to give you a hard time, but we have a lot of new people coming to this thread and asking the same questions that are answered in it.
TLDR, I get it, but if you have this problem, it would behoove you to read the 1800 posts.
My dealership told me that GM engineering informed them that the rear window were a one time use.  If the caulking job didn't work they could not reuse the old window. This was after trying to caulk the window 3 times.
Edited by JohnCasey
UGADawgs; I agree and understand completely what you are saying. I’ve read all the posts over the past several days as I had done all my homework and was planning to purchase a new truck this month. I was shocked to find this post and if GM is following this please be aware you should do something to resolve it.  But I’m still not aware of a consistent repair method resulting in a permanent fix for this issue. Yes, as many of you fine folks say that a “quality dealership”  that knows what they are doing can/will fix it but what is that fix? Sealant or new window + frame? I’m kind of in a bind as our local dealer has a horrible reputation, extremely limited supply of vehicles so I was planning to visit Everett GMC (based on positive comments I’ve read here) which is 7 hours away. So I can’t afford to run to Everett GMC with ongoing leaking issues. So unless I’m missing something the dealer repairs are hit and miss and even with a brand new 2020 there’s still no guarantee it won’t leak. That’s a $60,000+ gamble I can’t afford to take. Please tell me I’m wrong or missing something? Thanks in advance.
You got it 100%. If I were you, I'd hold off making a purchase until GM comes clean on what went wrong and what change they made with FUYAO E4 and/or what they are doing to fix this widespread issue. This isn't some bad power steering pump or infotainment system, issue. This is a leaking window causing collateral damage and multiple return trips to dealers with half baked fixes.
GM coming clean ain’t ever gonna happen. Design changes usually happen pretty quietly, and I wouldn’t expect anything different here apart from maybe an updated TSB.
I had thought about doing some “destination truck buying“ like Everrett or Laura...but doing so would have made every problem with this truck a million times worse. Thankfully I bought local. And thus have somewhat of a leg to stand on in their service department after spending 6 figures at their dealer recently.
People underestimate the value of that when they only shop the cheapest price. I wonder how many bad experiences in this thread are attributed to service by a non-purchasing dealer. I know it’s not what GM wants, but one has to imagine if the dealer doesn’t view you as a potential future customer, they might be inclined to screw you around, not give a loaner, and / or do shoddier work.
My local dealer added some urethane to my rear window last Thursday and it’s rained for the last 3 days and I haven’t seen a leak yet. They did a really good job bc it doesn’t look like they touched anything inside or outside the truck. It was kept inside to cure before they gave it back to me. They also said they’ve seen quite a few of these so hopefully they’ve got the fix down by now and I won’t have any issues going forward. I’m just gonna assume it’s fixed and keep checking it when it rains. Fingers crossed I won’t have any more issues. Just for y’all’s information my window is E9 and it was built in Mexico in 4/19.
On 2/29/2020 at 11:19 AM, Brandon Adams said:
So I finally got my truck back from where they damaged a bunch of stuff when they replaced my headliner. They're still fighting me over the gouges on the passenger a pillar. In the process of fixing things, somehow they broke a piece on my rear passenger door... what the heck?
I feel your pain. When I got mine back after two months they didn't mount the roof console all the way, the sun visor was hanging off, C pillar trim scratched, and the seat belts on backwards.
Well add me to the leaking rear sliding window. Took it in to the dealer on Monday. He confirmed cracked frame on driver side corner of the frame. Ordered a replacement on Monday and it is supposed to arrive tomorrow. Service Advisor said bring truck in on Monday to have it installed.
I will post an update on how it goes and the window part number installed.
On 3/4/2020 at 3:34 PM, Centrebaseball said:
One month leak free with my replacement FayUO E4
Mine is an E4 and it's currently leaking, my appointment was set 2 weeks out which is Monday 3/9/2020. The dealership said it would take 3 days but didn't disclose what their fix would be other than they are sending it to a glass shop. Fingers crossed that I am not going down a path of constantly driving loaners and a leaky truck.
So I got in my truck this morning... and it's leaking again. The headliner is wet on the passenger side again.
Was yours replaced or just caulked?
Sent from my Pixel 4 using Tapatalk
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
