This thread started Nov 14, 2018. It's been 18 months and windows are still leaking.
We need a poll for what will come first:
1) Statement from GM on why the window frames crack and what the actual solution is
2) Vaccine for Covid19
[emoji23] Definitely the Vaccine
On 5/13/2020 at 10:18 AM, hotrodz37 said:
Wow that’s bad. I went through a similar situation, bad caulk job that I got to stop leaking myself. Mine came along with damaged interior panels, paint chips and the sunroof shade no longer working.
Rear window was replaced this past week due to cracks in the frame all damaged panels replaced and feel like I’m whole again. The new tech did a fantastic job and there are actually less rattles in the truck then before which I am thankful for.
Poured all day yesterday and new window is dry - for now.
Fayuo E4 is the replacement and I have heard of people having good luck with those. If it begins to leak, most likely going to fix it myself this go round.
I'm tired of checking for water leakage every time it rains......after 14 mos. if it doesn't leak, it ain't gonna leak.
Fayuo E4 is for the glass and has nothing to do with the frame. Too bad not more pictures of the interior of the frame itself. And what's with this sealant? The number of casualties seem to be dropping off with time.......could it be that GM has already solved the problem but the solution too costly to retrolfit, let alone by half a$$ed attempts by inexperienced personnel at some dealerships? So all you get is the cheapest quick and dirty fix
I examined my frame and window carefully to compare what I could see in photos of failures. The top frame of my rear window is .065 cm or almost 3/10 of an inch thick at the spots where it typically cracks. Pretty thick to spontaneously crack....could be there is a rev on the frame and not the glass. In addition the whole frame is secured with black silicone rubber, not the snot they used to seal my leaking Silao Avalanche. Sealed to the body so tight there is no way in he!! that the dealer can remove that frame without breaking it apart and not practical to use the OEM silicone for field repair replacement installing a new frame because of prep time on surfaces, inconsistencies in bead placement and cure times........that's a job best suited for a GM robot on a freshly painted and cured surface and not some quickie job with a layer of crap they lay on top of leaking sealant that has already been compromised.
DSCN0948.JPG.51a11a92ad7678f784a4aaef7e05d786.JPGDSCN0950.JPG.b29127b1d48e45b963a3eb56c68d5ac5.JPGDSCN0953.JPG.1b705c81ab2140eb014466f53d6cfa86.JPG
Purchased a 19 Sierra at4, unfortunately I fell victim to this window leak. The truck is been at the dealership since May 8th, so its been about 10 days. Waiting on the bolts that hold the rear roof spoiler to the roof, my understanding is that the bolts have to be replaced after removing the spoiler. So that being said these bolts are on backorder with no ETA on arrival to the dealership. The truck does sit inside so I don't have to worry about more water getting in the truck, and they did give me a Camaro to drive in the mean time. But my question is has anyone had to wait for these bolts to come in and how long did it take to get some?
Bamx31, iam with you there man, mine has to have the whole rear window replaced. Brand new 2020 LT TB, they have to basically disassemble the rear cabin, seats taken out, all trim removed, haven't even made the first payment. If they damage anything, they are replacing (plastic trim) or fixing it( paint damage). .
I'm not 100% sure, I'm assuming it has something to do with sealing the spoiler to the truck better than what the assembly line put on.
@Nelly13 iam asking becuase i just fixed mine not too long ago, put a ton of blue gasket maker around the nut, hopefully it doesnt leak. The dealer gave me some nuts to put on there, he also said they are a one time thing. The ones he gave me didnt look like the ones that came off the truck(they were smaller and different design), so i just reused the originals, time will tell.
Yeah my service advisor told me they redesigned the nuts to pull the spoiler closer to help seal it better, as I've been told. Just hope they get the nuts soon. Driving a Camaro is fun but doesn't compare to these trucks.
Nelly13 ill ask him to order me some also! Yeah these t1s are badass, i love my truck man, these little problems are annoying, but hell, nothings perfect or made to last forever. Lets enjoy it while we can. Hopefully you'll get yours back soon.
I have a 2020 Silverado 1500 Z71 LT. It's certainly not a first-year problem because mine is leaking too. Same place everybody else is talking about, on the passenger, side upper right-hand corner of the rear window itself, not the slider. I live in California, the only way I noticed it was the hard water deposits dried up on the window after I washed it the second time. Not a major problem but has to be taken care of because it will get worse. I hate taking my Factory original built vehicle to those clowns at the dealer to half-ass a repair or r/r the window. It'll never be like the factory installation... But maybe that's a good thing!
Mind getting a part number for these redesigned nuts?  I hate walking into my dealership without something like a TSB or part number in hand and everyone claims to know nothing about it.
Then mine must be an odd one as that's the area I have been checking since I read this post, turns out mine is on the drivers side!
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   1 Member, 1 Anonymous, 1,025 Guests (See full list)
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
