2019 RST Crew Cab sliding window leaking on both sides. Headliner is stained, the jack and seat brackets are rusted. The dealer performed the TSB farmer fix with seam sealer yesterday, I will pick it up tonight to see the damage... I am looking to trade it for a solid window 2021. There is no way that I can keep this truck without a true fix...
I called GM 20 times until I talked to someone but it was no help, to get out of the vehicle even though this is a known issue without a fix, I am on my own is what they told me. I am absolutely disgusted with this whole deal.
All, I have followed this forum over the years whenever issues came up.  Had two 2017's with nothing but issues and up until last week, no major issues with my 2020 at4.  That is when I noticed old water trails on the inside of my rear glass.  Straight to the carwash to verify, and sure enough I have 6 or so cracks in the window frame and its obviously leaking.
In my line of work, I have a client that owns a local glass repair company.  I gave him a call to check the aftermarket for a replacement window, because I do not want to deal with my dealership for many of the reasons listed in this forum.  He actually found an aftermarket electric slider available for our trucks.  It is a non Fuyao make.  They have ordered it and will inspect it, then advise me on the best course.
Just wanted to give everyone here a heads up that there is an aftermarket option.  Yet to see if it is a better option, but its an option, nonetheless.  I will most likely go with aftermarket glass and pay them to repair, rather than screw around with my local service department, which sucks, at best.
Definitely keep us updated!  I am willing to pay out of pocket for aftermarket instead of dealing with a faulty dealer part time and again.
From what I’m being told it’s about $425 for the aftermarket solid with defrost to $525 for a factory solid GM window installed. Sounds like cheap insurance. The aftermarket slider is a thought but probably coming down the same line.
Thanks for the info Blue. Mine is going in tomorrow for them to try and seal the window. My dealer uses an outside glass specialist and he has apparently done a bunch of these so far, so we'll see. I'm giving them 1 shot at fixing it. Once it leaks again I am going to go the solid window route.
Same here. Had to make an appointment because my dealer calls in an outside vendor who has done these. We shall see......
Any information from your local glass repair company on the Manufacturer and Model # of the aftermarket electric rear slider that they ordered???  I am in possession of a new GM 84944319 but have been hesitating to have it installed if it will not solve the leak problems I have experienced with the previous OEM slider.
Called a local non chain place and they want $675 to install a solid window. Same price regardless of brand.
I spoke with him this afternoon and the new glass was delivered to them today.  He did not go over part numbers, but did mention the manufacturer was ATI.  I believe they produce OEM for Chrysler etc. and aftermarket.  So it is indeed different than the OEM GM glass.  They are bringing in their tech managers to all put their heads together.  He said I had evidently opened a can of worms, some of their techs are brought in by dealers, some of them do no work for dealers.  Several techs in rural areas were well aware of the issue and have worked on dozens for GM dealers.
The company owners now are considering not touching any sliding windows unless under contract from GM.  They don't want the liability to fall on them if someone comes directly to them, bc if the truck is less than 3 years old, they order OEM glass, which we all know will just crack and leak eventually.
Anyhow, they are going to study the aftermarket slider and compare it to several OE GM rear sliders and advise me after they have done so.
supposed to be looking at a 21 elevation with a sllider this weekend. this thread doesnt give me the warm and fuzzies. current truck has the solid window and obviously no leaks. what are my odds....50/50?
Probably 25% no leak, 75% for leak.
Unfortunately, since I learned of this issue all of 3 days ago, I have reached out to 4 of my buddies and my father who all have 2019+ trucks with sliders.  All of them, except my dad, have leaks that they were not aware of until I explained this issue.  Been driving around leaking water unknown for months and years, just as I have been.
I agree with the post above.  I think many people are driving around without any clue there's a leak happening.  Especially if the headliner is not showing any signs of water.
I wouldn't have known to look for a leak if it wasn't for this forum/thread.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
