You're talking about auto trans compatibility and then say both are manual trans (dog leg shifter)? Wat? Unless you're mixing up colloquialisms and are meaning that both are a floor shifted transfer case. Ignoring that, the 96 trans will physically bolt up to the the 5.3, but it won't have the bolt hole at 12o'clock that the 5.3 has. Also, the valve body and torque converter are different, as well as a couple other things. It's not worth it IMO. You're better off getting one near or the same year you're putting it into.
