Running Board Pics
reihart
I'm considering purchasing running boards for my truck and I can't find very many pictures of trucks with different ones. So if you have aftermarket running boards, could you post pictures of the whole truck? (not just a close up of the running boards)
I don't have pictures but the amp power running boards I have are pretty slick. I'm not stoke on the obd connection but hmtgey do the job and tuck nice. Doesn't even look like I have any!!acd9395c8bcb0ba456d580e43389b477.jpg
Sent from my Pixel 3 using Tapatalk
These are what came with the truck when I bought it from the dealer used. They are Luverne MegaStep running boards. They are alright but my only complaint on them is that the brackets that mount it to the underside of the body had to be notched out a little on the front bracket mounting area. The bracket was rubbing on the body and would squeak anytime someone would step on the board. I just pried it over and then ground off a little metal on the plate and it works fine now. The other complaint on this is that the chrome outside edge scratches soooo easily. Just from me getting in and out I have my pant leg rub on that spot and my shoe bumps it and there is a dull spot right where I get in from rubbing on that part of the chrome edge.
Without and with nerf style - cheap eBay specials since I wasn't sure if I wanted any. Wish they were more like 2017Darkness has - more flush to the rocker. They get the job done...I like the GM's without boards though.
43193464_10155570771677274_969238591014174720_n.thumb.jpg.e08a6646b63e131000a52d62fe08722e.jpgSnow.thumb.jpg.b621c07ff3889669c5a19666e2d63c61.jpg
  • 1 month later...
On 12/19/2018 at 2:00 AM, ftwhite said:
Halfway through swapping factory flat chrome for factory round black.
My truck has the flat chrome ones, learning very quickly that they suck. Had the nerf tube style on my 04 i just got rid of. Liked them much better.
On 12/19/2018 at 3:23 PM, 2003 SSEi said:
I removed the OEM chrome 6” steps, and installed the GM 3” Off Road Steps
4C422FFF-3B8F-44CE-B59E-3FBE0E415F79.thumb.jpeg.ee0dbc7ccabba689c7fe7d9a72f5e5be.jpegD4CD14B6-A585-4581-90CB-60670FFAC9D2.thumb.jpeg.48cb91c0d6a5dfa0a315761a74dc67c1.jpeg
What functional differences have you found between the 2?
to be honest, Nothing really.....if anything at all the 3" step pad is ever so smaller.  I liked the looks of the tubular steps over the wide flat chrome steps.  The 6" wide chrome steps made the bottom of the truck too chunky IMO
That's what I think, too. Do the 3" step pads seem any lower/easier to use height wise?
Sent from my SM-G955U using Tapatalk
    • 3.41 Kroger’s in Montgomery TX
    • I really wanted to go to the Fox 2.5's But they were like ~$1,500 vs ~$425 for the Bilsteins. And my research on FOX shocks was that they do not have a great reputation for longevity. I am sure they the FOX's are fantastic, but I know from experience the Bilsteins are rock solid for at least 150k miles.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
