On 2/15/2019 at 2:23 PM, Robwcormack said:
Anyone know of any way to add wireless charging to the '19 RST or LT?  curious if maybe the module from the 16-18 would go under the cutout in the lid since there's no little shelf or whatever that is built into the center part where the wireless charging is on the ltz.
On 2/22/2019 at 12:31 PM, Ben Berkenpas said:
I did mine myself in center council of my 19 Trailboss. Went really well with a little work and some ingenuity! Cut apart a triple coil charger off eBay. Paid $12 for it a couple years ago and wasn't using it anymore. Opened up the bottom side of the lid, ground it out with a Dremel tool, glued the modified charger in place, ran a charging cable from the USB in the counsel to the charger thru the hinge, put it all back together and it works awesome. Radio has to have power to it for it to be on!
(I can only get 2 pics at a time to attach so it going to be a few post)
The factory chargers are weak and useless and unless in direct contact with the charger most will not charge through a rubber mat in a protective case.
No need to knock yourself out making modifications.
Easy peasy...under $30. ..Go to Amazon or EBay and get the full console or arm console insert tray and a wireless charger with USB pigtail. (Get a separate tray and charger...been there tried that, .the trays with a built-in charger are as crappy as the OEMs and need a sweet spot for charging and cannot charge through a protective case). Has an indicator light, but no need to even look when charging, a large sweet spot just throw the cell phone onto the tray pocket close the lid, leave it there and use the Bluetooth connection. In cae you forget to take it, it is in the console safe from prying eyes.
https://www.amazon.com/gp/product/B07DN4GSM6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
https://www.amazon.com/Console-Organizer-Silverado-Accessories-Secondary/dp/B07SPVZSZ2/ref=sr_1_4?keywords=silverado+console+tray&qid=1582894982&sr=8-4
DSCN0825.JPG.718b798acd10459ce831bd699678d2da.JPGDSCN0826.JPG.b3ba6fbc3d9deee8bc39e1548dfa658a.JPG
Was going with the before mentioned single coil disk.... But decided to step up my game to 5 coils!!!! ?
Will be installing tomorrow... Will report back.  Size is almost the exact same size as the phone tray in center console, so should work beautifully.  Going to tie the power into the rear 12v.
Here's the part I used:
https://www.amazon.com/dp/B07PYQQ1R7/ref=cm_sw_r_other_apa_i_R2ZwEb6850DQB
Getting the cover off this larger one was infinity easier than the small disc one.
Edited by Swiftks
Great find, I put a 3 coil one in my center console, works well but wider coverage area for different sized phones would be perfect.   Looks like it will fit
Fit was perfect... Epoxy is drying now.  Then have to do the wiring.  Will post complete install pics later this evening.
This is how I decided to do it for now. Want to wire it in so I don't lose the USB port on the dash.
Edited by Fyreman97
Some pics of the install today.  Epoxy isn't pretty, but can't see it at least.  Drimmel made short work of the plastic tabs.  Wired into 12v at rear.  Works good.  Size is perfect.
Edited by Swiftks
Looks good, The 3 coil is working but I’m glad I didn’t glue it in, because I’m going to switch to this 5 coil version!
3 hours ago, Michael Summerford said:
Which wires did you hard wire too?
Sent from my Pixel 4 XL using Tapatalk
tapped into the 12v outlet wires, to get more power.  It's always hot, but shouldn't be drawing any power unless something is charging on it.
you 100% sure on that?
Even if there is any power draw, I'm pretty sure it would be minimal.  I mean it would just be keeping power supplied to the pad.  If nothing is on the pad drawing power, then I don't see how there would be any significant power draw.   I mean if you keep a car charger or radar detector plugged into the 12v 24/7 do you really think it's drawing enough power to affect anything?  The original guy in this thread did the same thing in September, he hasn't complained.  I guess time will tell, but I'm not worried.
Edited by Swiftks
It depends on the charging pad and the electronics it has.  And cheaper pads will have cheaper electronics...
With a charger that you plug in, it's fairly straightforward to tell if something is plugged in to it, and make it so it draws little to no power when nothing is plugged in.
With a wireless charging pad, it is not easy to determine that something is there to receive the wireless power.  And most of these installs put the charging pad underneath something else so it can't be seen, so they can't use a microswitch to tell if something is placed on the pad (it either doesn't get pressed, or is pressed all the time from whatever is between the phone and the pad).
Did you install the charger with the coils exposed or did you put it all back together and then install? Did the bottom of the console lid go back over top of the charger once you had it glued in or no? Sorry,.. really want to do this but also nervous about taking a dremel to my brand new truck.
Yes, I installed with coils exposed, and the cover went back on, just fine.  The area you drimmel out has nothing holding the cover in place, so doesn't effect anything.  Hardest part is epoxying the thing in place.
Since I guess it's been a couple of weeks now, have you noticed any drain on your battery that would be more than leaving a phone charging inside? I would like to run it hot and I hate that the USB won't charge my phone with the engine off.. which is a terrible design flaw if you ask me. I'd like to be able leave the phone on the console and have it charging while I'm at work.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
