Looks like they have a down pipe with high flow cat coming out soon. Curious how this intake performs. Pics and videos please.
When is this engine going to be available in the Tahoe/Suburban platform? Or will it ever?
For those who have had the 2.7 for the past several years, how’s it holding up? Better mpg?
As well, does it come with a g80 locker, was thinking 4x2 crew cab but my only concern is traction in snow. Not for off-roading.  I know tires and weight make a difference. Thanks
As for the mpg, I have 5000 on mine and am averaging 23.1.
As for traction, it has plenty of power to spin the rear easily. Much more so than the 16 silverado I had with the 4.3.
Almost 4,000 miles on mine  (4 x4) and  last tank 26 mpg on highway (driving 55)   22-23 around town
They've only been around for 2 model years so I don't think you'll find many people that have put 30-40k miles on them. I got mine a month before this COVID bullshit so I'm getting tremendous mileage. 1-2 weeks to a gallon probably. [emoji23]
Get the diesel you won’t regret it and it comes standard with the 10 speed.
And it's only  about $5,000 more
$3800 it’s a bargain. Includes the 10 speed.
Edited by ILSilverado
I am thinking of trading in my 2015 1500 Silverado LT 4.3  for  the  2.7, but after researching the mpg I am hesitant, my 4.3  constantly gets 22 to 23 mpg ( rural driving )  and have had up to 25 mpg driving 75 mph in the mountains of Colorado. So the gain in mpg of one truck over the other isn't much.
Wondering what other's opinions might be on my thinking, a new 2019 or 2020 with 2.7 would be close to 12,000 and my trade in. Factory discounts aren't as much as back in the winter on this set up,
I think you are missing the additional all - star discount you get with the 2.7, again at lest $5k more.  When I bought mine, (11/19) I got about 30% off the MSRP  as they were  almost giving the 2.7 away.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
