Ready for some travelling soon. Forest RIver Salem Cruise Lite 17'. Added the GM trailer camera system too.
A few camera views here.....
Default view from side mirrors
https://www.youtube.com/watch?v=zhMS11KDJQU
Transparent Trailer Cam view
https://www.youtube.com/watch?v=eiTgTIGAqFw
Edited by richmz
Nice! What engine/tranny do you have? How does it pull? How is the squat?
It's the AT4... 6.2L gas with 10 speed. Pulls like a dream. Trailer weighs only around 4,000 lbs plus the water tank was full, so maybe 4400 or so, but when we go off fully loaded with stuff it'll likely be around 5k.  No Gray or Black water in it when I test drove my setup after they delivered it.
The trailer rating for the truck is 9,200 lbs. I have a load leveling hitch setup and set it so the truck is within about  1/4" or so from the unloaded level position. No squatting. IIRC when I first connected up it only squatted about 1 1/2" at the rear bumper which surprised me. After I set the torsion bars to raise it it came right into it and leveled off nicely.
I had a '06 Silverado(5.3L, 4 Spd auto) for 15 years and towed my 23' Continental enclosed car trailer(cars were about 3,500 lbs, total about 7,000 lbs) and it always struggled and I always had to drive in D3. The '06 was rated about 7,500 so I was using all of it.
Night and day between the 2. That's why I upgraded to the 6.2L, knowing I'd be better off, but didn't want to go the HD 2500 route or get into a diesel.
Rich
PS the last 3 photos..... I had 23 bags of bark mulch loaded in the bed when I took those photos. I was amazed how it held up. When I drove back from HD all loaded up it felt great. Amazing truck.
Edited by richmz
typos
1 hour ago, richmz said:
It's the AT4... 6'2L gas with 10 speed. Pulls like a dream. Trailer weighs only around 4,000 lbs plus the water tank was full, so maybe 4400 or so, but when we go off fully loaded with stuff it'll likely be around 5k.  No Gray or Black water in it when I test drove my setup after they delivered it.
Rich
Thanks for the info. The older 5.3 is a good chunk less powerful than the new ones. And the 4 speed is probably what killed you. Looking at a trailer that is around the same dry weight. Didn’t know the 6.2 was that much heavier. My 5.3 weighs about 220 pounds less so the max is 9400 and 940 tongue weight. Or maybe the GMCs are heavier???
Yes the old iron block 5.3L Vortec was ok and a better choice over the base(4.6L iirc?) at the time. I've read about the present aluminum block Ecotec3 5.3L version being more powerful.
My '06 was 4WD so it likely dropped the tow capacity down a bit due to added weight . It had the HD Trailer Tow pkg. Not sure if that actually adds weight or not, or is a wash for the tow capacity.
I'd imagine the same with the AT4  being 4WD that they drop it down a bit from a 6.2L base rig in 2WD. The 6.2 is likely a bit heavier than the 5.3 but probably not too much. Is yours 4WD? If so then maybe as you said the GMC flavor may be a few hundred pounds heavier and they have to drop the tow rating to compensate.
Rich
Rich
That's a good looking truck and a nice set-up.
I am somewhat surprised at the difference in the load & towing capacity when compared to my 2020 Silverado, Z71/RST, CC, 5.3L.
When comparing the capacity stickers, my 5.3L, Z71/RST, CC, is 375 lbs lighter (5179 lbs), has a max payload that is 475 lbs more (1921 lbs), a conventional towing weight/tongue weight rating that is 400/40 lbs more (9600/960 lbs), and a goose-neck trailer/tongue weight that is 1900/285 lbs more (9500/1425 lbs).
I guess I am most surprised by the difference in curb weight and max payload. The max payload difference is around 25%. That said, it's hard to argue against the power of the 6.2L in a pick-up truck.
Looks like you have a comfortably paired combo of truck and travel trailer. Enjoy the travel.
JMHO
No expertise implied or expressed.
Rich
5.3 10 speed Trailboss
3 hours ago, Coles5515 said:
What size trailer is that? Motor/trans?
Its the Cougar 27RESWE so its about a 29' trailer in total. The truck had the 6.2l with 10 speed. I say had, because after crunching the numbers, with truck, canopy, passengers, dogs and trailer tongue weight I was about 500-600lbs over the payload of the truck as it did not have the HD package. Long story. We took it from our home in Oregon to Flathead Lake in Montana and the truck had no issue towing the setup, I am just a worry wort, and didn't want to give the insurance CO any reason to deny a claim should anything happen. Stepped up to a 2020 2500 Denali. So that setup was do able, just not for me.
Oh also the 6.8-7.2 MPG sucked towing. I expect the Duramax to do much better...
Hey guys. Does anyone have any real world examples of a 1/2ton truck towing another 1/2 Ton truck?
I have a 2019 trail boss LT 5.3L v8. Want to see if I can tow my 2011 silverado extended cab also with 5.3.
I ran some numbers and I am coming up with a technical “yea” I could do it. But I’m planning on a 6 hour drive over the grapevine in CA (big elevation changes). I used an online calculator and had to input a couple variables like - guessed that the trailer would have GVWR of 10,000lb (pj trailer buggy hauler model) and that the trailers “cargo weight” is simply the curb weight of the 2011 truck being towed which I put in as 5500 lbs.
Here is the trailer sticker from my truck.
I’m debating renting a 3/4 ton truck from enterprise instead.
Your truck can do it in my opinion, but you are close to it's limits and with inclines and declines I'd feel much better if I were in a 3/4 ton with better brakes, I'm not concerned about suspension, brakes are the big thing in my opinion.
Just my .02
I am surprised by how poor your mileage was towing.  I have seen as low as 4.5 mpg pushing hard with big load going up steep hill, but overall tow cycles are in the 8.2 to 9.6 range.  Can you tell us how much your trailer weighs, how  tall, type of towing terrain,- over mountains - head wind and your typical towing speed - other factors that may have impacted that.
I only ask as I had a 2019 AT4 - 6.2 10 speed - towed about 10k miles with that and now have a 2020 AT4 (6.2 10 speed with tow mirrors) and have towed about 4,500 miles with it.  The 2019 on a typical trip got 8.2-8.8 mpg - the 2020 on my last two trips (450 miles +/-- round trip) got 9.2 and 9.6 mpg respectively.   All towing a 24' Inteck race car trailer (30' overall length) loaded to about 8,500 lbs.
My typical tow loop is from Orange County to Sand Dunes (Gordon's Well - south end of Glamis) and back - which includes up and over a 4,200 foot grade over and back (about 50 miles of the trip is up and down in the mountains), there is aways wind in the mountains and often a head wind the last 5 miles out of the desert before you head up the mountain.
It's a 29' TT it's about 10'6" tall that weights in at about 7700lbs + passengers+150lb of dogs. It was from Oregon to Montana so there was a bit of mountain towing. Don't recall too much wind.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
