Anyone else notice that their cab/ bed are out of alignment? I've had my AT4 for about a week now, and when I first noticed this in my mirror I thought I was losing it..
On the driver's side of my truck the cab sticks out at least a good 1/4" past the bed side, and the body line doesn't line up. The passenger side is flush and laser straight.
I tried taking a couple photos, but it's quite difficult to capture with reflections. Am I the only one? Is this worth making a big deal about? 8388124f16a738bde132f507db61a96f.jpg525e664f18fe77c9bf7387c9ae98bd3e.jpgf5ce965db587455c5997ca318b630cb2.jpg
Sent from my Pixel 3 XL using Tapatalk
Take it to the dealer. They can loosen the bolts and adjust the alignment. Pretty simple fix and very common issue across every single brand of trucks.
Most of the time they are all a bit off, but that's real bad. There was another post on here about it but people were claiming no bed adjustments on the new trucks.
A lot of F-150 owners had the same problem, it's an easy fix. Seems to happen with all pick-up trucks.
Yes, I just bought the Trail Boss and mine is off on drivers side only, about 3/8". Took it back to dealer to express my concerns and the service manager contacted the GM rep and said this is the first he had heard of it. (figures), Service manger said new trucks have alignment pins and moving the bed/ cab was not possible. I hate paying that kind of money for a crooked truck.
Let me know if anyone knows of a fix.
Thanks
All the other pickups since 07 had an alignment pin as well. There’s still room for adjustment. If your dealer has a body shop, bring it over there and they’ll adjust it. Mechanics don’t like doing body adjustments.
Its in the shop today for Tonneau cover recall and bed alignment.
People kept telling me I was crazy! My 2018 sticks out about a 1/4 inch on the drivers side. Still under warranty so I’ll be getting it fixed.
So dealership said its definitely misaligned and I made an appointment with their body shop for Thursday to get this fixed. They said they would get it done.
Today I had all 4 tires rebalanced as they were way off from the factory.
Had mine in the shop on Friday, mechanic moved bed over to the drivers side, but its still about a 1/4" off. Mechanic said all the adjustment was gone unless bed is removed and drill out holes.
Mine is off 1/4” in the drivers side and flush on the other. I checked the tire pressure and parked it in my level garage. Took a 4’ level to use as a straight edge and checked both sides. The cab on the drivers side sits 1/4” outside the bed. The passenger side is flush.
I had a long talk with a GM Body shop manager about fit and finish in cars versus trucks. He also recommended I walk the lot and look at alignment in beds, doors, hoods, etc.
I believe I will leave it alone. With a square bed and square cab there has to be a reaction to every adjusted made. I am not sure that I want a bunch of shop hands leaning and pushing on my truck to gain an 1/8” in alignment. After looking at about 10 trucks today I came to the conclusion that the bed must be slightly narrower than the cab - maybe 1/4” to 3/8”.
As long as my dogs, chickens and deer don’t know it I think I can worry about something else.
Call me crazy or lazy but I don’t think I want to deal with sales, service or body shop and be without my truck over such a minor issue.
2019 Sierra AT4. My body line is 1/2” off. And 1/2 sunk in width wise. So far I have gotten no where with the dealership. They first told me this was not a warranty issue and I was going to have to live with it. If anyone gets any traction. Please let me know. I am extremely disappointed. Thanks
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
