On 8/16/2019 at 6:48 PM, 17Allterrainx said:
Installed the AT4 Rough Country 2” leveling kit. These are the after results!
How do you like the Rough Country kit I was thinking about going with it for my RST
2.5" level kit and 1" wheel spacer up front.
Rear left stock.
OEM LT rims with 35x12.5's
Look great! Any rubbing issues with the 35s? Did you use the spacers for clearance issues or just for looks?
Sent from my ONEPLUS A6013 using Tapatalk
For the price you can’t beat it. I haven’t had any issues but I have noticed a slight humming coming from the front wheels at like 90+ mph. Idk if its the wind hitting it or what. Haven’t really looked into it.
If anyone is interested I have  a brand new Suspension Maxx leveling kit for the 2019 denali 1500. It is a 2.5 in front and 1.5 in back. I have the full kit still in box Im just deciding against putting it on because I do not think it will fit in my garage if I install it. If anyone is interested let me know.
Rubbing? Oh yeah! The spacers were needed for clearance at the upper control arm. Could've got by with 1/2" but I wanted the front out a little bit. Along with that and the front only lift/level, I was shooting for a stance similar to the baja trucks. Without the mudflap mod, I still had only 22-23° of turn availible till I could hear rubbing. After removing the rear fender mounting bracket and pulling the inside of the mudflap to the frame rail, I get 35ish° which is almost full lock.
2” Motofab up front. 2” Motofab blocks on rear.
(I like a little rake)
Cooper Discoverer ATP 275/60R20
Edited by Method2Madness
  • Like 4
On 11/21/2019 at 2:01 AM, 17Allterrainx said:
Replaced the OEM Bridgestone Duelers for 35” Nitto Ridge Grapplers. 2” RC AT4 leveling kit. Zero rub.
Are those 11.50’s or 12.50’s?
Went back out and took a pic in nearly the same spot as I took the before pic.
(2” leveling up front, 2” block in rear)
  • Like 4
On 11/4/2019 at 11:03 AM, Silver2019 said:
Please do!
On 11/7/2019 at 9:10 PM, econometrics said:
Yeah! More pics, please! I have the exact same truck and have been wondering what it would look like with a 1.5” and 285 or 295 tires!
Can you post some additional pictures? Id be doing a similar setup.
How does the ride and handle compare to the OEM duelers? I have an older Tahoe that rides like crap since I added 10 ply tires...wanna avoid that mistake with my new truck...
On 11/7/2019 at 9:13 PM, Chance1025 said:
This is my Trailboss, with the black parts deleted, and a 1.5” level on 285/65r20 KO2’s. Love the ride. Feels like stock.
Dang, that looks nice. Did you notice a big drop in power with the heavier tires? How about ride quality and handling? I want the exact same look on my 5.3 LTZ. I wanna go with the same tires as you or the 35x11.5x20 ridge grapplers. Thanks!
Thanks man! I have always loved these BFGs. I got the 285’s and honestly they do look a hair small. They are a tall tire, but just a tad skinny in my opinion. I did that on purpose though, because they offer a little less weight (drag) and better fuel economy than the 35x12.50’s in the same tire. Power loss is negligible. Ride is close to stock, but with the 10plys and the leveling kit it’s a bit stiffer. I’m running them at 35psi cold, which has helped some. Handling is nearly the same. A touch more body roll, but that’s bc the center of gravity is higher, and I kinda like that fee anyway.
I have had BFGs on my last three trucks, and know how great a tire they are. But I LOVE the way the Nitto Ridge’s look. If they weren’t so heavy I prob would have bought the Ridge Grapplers in 35x12.50’s.
Edited by Chance1025
I’ve had two sets of Nitto Ridge Grapplers, both had their siping wear very fast and started slipping with almost 15k - 16k miles on them, you’d be better off with KO2’s.
KO2’s have siping that runs straight through the lugs
The Nitto Ridge Grapplers siping reminds me of an after thought and wear quickly
New
With 16k miles on them, siping wearing prematurely creating slippery nerve racking moments.
There was a study done by a marketing firm some years back, people prefer the chunky sidewall and that’s why Nitto Ridge Grapplers became such a big hit but it’s a phase, stick with experience and you’ll be fine.
Sent from Above
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 452 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
