This will give you about 3/4" rake. Feels fine. If you are just occasional 4x4 driver your all set. Makes a 1500 the same height as a factory 2500HD. If your serious 4 wheeler;
You would want to add a custom upper control arm with the correct
Ball joint angle to match a 3" lift.
And if your getting radical some longer shocks on rear.
Good Luck.
E
Edited by 2019 Sierra Me
If anyone who swapped out their stock trail boss wheels is interested in selling let me know. I'm looking for a set of 18s.
I have a set for sale. 7,500 miles on them. No scratches or curb rash. Wheels have been ceramic coated. PM me
2" Motofab lift front & rear
Fuel Shok 18" x 9" +20 offset
Nitto Ridge Grappler 275/70 18
No rubbing/no trimming 60910d6b3706e96863553bcc13582685.jpg38ee43fb9792b3401cc4480641abd815.jpga724bc2653bcf6d901e107e2361541aa.jpg
On 10/2/2019 at 10:38 PM, Breceda2019nali' said:
Wow. Now that's a Stormtrooper! Sweet looking truck!
Thanks brother!!
On 10/3/2019 at 5:51 PM, cal19 said:
Just put a new set of wheels and tires on my 2019 LT Trail Boss yesterday. The look and stance came out just how I envisioned it! (Don’t mind the dirty truck)
295/60/20 Nitto Ridge Grapplers
20” Trail Boss Replica Wheels +15 offset
NO Leveling Kit
NO rub!
Any more picture? That looks great!!!
NO Leveling Kit
NO rub!
Are those the satin or glossy finish? I was on the fence between fuels or these and your specs just made up my mind.
3.5" CST Lift with 285/60/20 ridge grapplers +1 offset fuel 20x9s.
no trimming or rubbing
  • Like 4
Black Rhino Stadiums 20x9.5 -18 4.5 backspace. Hub centric rings from 78.1-112.1mm
Tire size 295/65/20.
Lift Ready Lift 4” SST
  • Like 4
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
