2020 - 2019 GMC Side by Side
This picture shows how much bigger the new generation trucks are compared to the 2019 trucks, big difference in the cab height....it just looks massive to me.
36 minutes ago, Pastusak.t said:
Wow. Can’t wait to see one in person. Really wanting an at4
I really like AT4 HD as well. As soon as they offer the 10 speed with the 6.6L Gas I may have to trade up and add on to the garage to fit the gigantic new beasts.
My same thoughts. I have a 16 gasser now. I just want the 10 speed and adaptive cruise and I’ll probably pull the trigger.
drove a chevy duramax  yesterday - it rode great compared to my 2009 duramax. i have a denali duramax that has been built since 6\18  - just waiting on delivery
Test drove a 2500 Denali Duramax today.  Loved it.  Waiting for. White one and the AT4 to come in to compare and pull the trigger.
Enlarged it a little, took out the lens curve from the wide angle shot, cropped out the sky, and reduced the overdone HDR a bit for a better comparison (in case anyone else wanted to see).
I'm probably going with a 20 Denali and want adaptive cruise, however my understanding is that the 20's are not coming with adaptive cruise.
Yeah... the 2020 1500’s have it. So maybe the 2021 hd’s will too.
Sweet baby jesus that looks so much bigger. I saw a 1500 AT4 at the dealership while getting my collapsed lifter fixed and it was huge. I can't imagine how big the HD AT4 is going to look like. I am looking to upgrade to a 2500 next year and may need a bigger driveway.
Man...I hope chevy brings back the 1500HD option because the 2500HD is a monster,  where can you even park that thing lol.   I bet its size will cut down its use as a daily driver drastically.    It probably tows fantastic tho.
I really wanted a 6.6 gas 2500HD but honestly Its size I could only use it towing.  Could you imagine parking that thing in a major city?  I thought the precious 3/4 tons you could at least swing it as a daily driver if you wanted.    This thing looks like that mini semi truck International CXT made back before the oil spike
I had a 2500 as a daily from 2010 until last month.  You get used to the size and will come to look down on 1/2 tons as insubstantial.
Here is my current daily. It felt big for about a week, now it is normal.
I don't think there is 'extra' lift on the HD version.
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
