8 hours ago, BLKDOUTSILVY said:
Do you have a part number for this CHSML? I will need this as I already have the cargo bed camera.
Sorry, factory ordered mine so no part numbers.
You mean you already have a CHMSL with one camera built in?
If so, you'll want the one with 2 cameras (they are side-by-side in the centre of the housing, below
What year, cab and trim are you wanting to fit this to?
One version puts bed view into rearview mirror, the other onto infotainment screen.
Depends on trim and options installed.
fwiw, there are also 2 rear vision cameras. (one is HD)
I don't know if the 2 camera chmsl has both regular and hd rear vision versions or if all the 2 camera ones have the HD rear vision.
Edited by redwngr
I have a 2022 2500 HD Denali. I have the CHSML with 1 camera that shows the bed on my infotainment. I am wanting to add the camera and mirror for the Rearview capability.
Wow. Surprised your Denali doesn't have it.
Both my, 21 and 22 Denali's have it. I detest  mine.
Yeah I was surprised it didn’t have it either. Are yours 1500 or 2500? I wish I had the powered up/down tailgate, rearview mirror screen and HUD but I did not order this vehicle, it was on the lot.
The 21 is a 1500 carbon pro with the 3.0 diesel and the 22 is a 3500 drw with the 6.6 diesel.
This is what the 2 camera one looks like on a 21 1500 Denali (came with optional Technology Package .
CWM   Technology Package, includes (UVS) HD Surround Vision, (DRZ) Rear Camera Mirror, (UVN) Bed View Camera and (UV6) Multicolor 15" Diagonal Head-Up Display
On my 2021 1500, I ordered it for the 'bed view' and HUD.
I love the HUD, but always use the regular mirror mode instead of rear camera mode.
On 2022 2500 Denali it is also optional, under the same RPO code, along with the HUD
CWM   Technology Package, includes (DRZ) Rear Camera Mirror and (UV6) Multicolor 15" Diagonal Head-Up Display
On 2022 2500 Denali, bed view camera is standard
UVN   Bed View Camera, camera in the CHMSL to show a view of the cargo bed, display located in infotainment screen, includes Two Trailer Camera Provisions
Awesome! Thanks for showing this. Now I just need the part number to that CHSML and then hopefully I’ll be good to go.
Just wanted to say thank you for the great write.  I just finished the install of the Mirror camera.   The detail of this thread made the install very clear.   I was able to complete the procurement for around $500 in parts.
I finished the install today, did it at the same time I sealed the slider from leaking.  Also installed a lead for my radar detector.  I like the camera mirror!
One question did anyone run into an issue where the mirror cover did not fit after the install of the upscale mirror.
I had/have the narrow cover mirror cover.  once I added the new mirror the cover no longer properly locked into the mirror bracket as unit  is of course physically different.  I did buy the upscale cover for non collision setup but it looks like the mirror on the upscale trucks location is lower then the non upscale.  so the new cover does not fit.
Did anyone run into this issue and what did you do to clean up this up.
As of today I have the old cover on with the wires stuffed in it.
thank you in advance.
  • 11 months later...
I know this is a really old thread but I thought I would mention what I'm going to experiment with.  Using the information from this thread I am going to use the drz video mirror and the rearview camera.  I also found a FAKRA video switcher that I plan to use in conjunction with a backup camera and the rearview camera. I will connect the power for the video switch to the reverse trigger and display the backup cam on the mirror when in reverse and the rearview when not in reverse.  All the parts have been ordered and are in transit.  I will keep you posted.
On 7/9/2021 at 8:58 PM, Rally6.2RST said:
84486910 is the camera part number
and if you need a mirror, there are some very very nice video DRZ mirrors on ebay right now (i may be the seller).
Trying to do this a inexpensively as possible, does the mirror just have to be DRZ?
These guy are awesome at Gen5diy, I am now able to add the LCD mirror to my WT yes my work truck.  They are sending me the harness seen in the video below.
I ordered the mirror from car-part.com
Edited by passat774
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
