**ENTER BAJA KITS STOCK WIDTH FULLY FABRICATED UPPER AND LOWER CONTROL ARMS**
I have been waiting for this suspension kit to come out since I bought my truck. It's compromised of the upper and lower suspension control arms and is stock width. This is unique as most 'prerunner' suspension kits are extended in length to provide more wheel travel and a wider stance. I didn't want to go with a wider kit as you must use extended steering tie rods and front driveshafts, fenders, etc. and all this starts making the truck less enjoyable as a daily-driver . By going with this stock width kit I am able to keep my steering and driveshafts OEM, doesn't require fiberglass fenders, and keeps the stock geometry of the suspension.
Kit is adjustable from 0-3" of lift, although I feel like it brought up the front more than my 3" leveling kit from Moto Fab Lift did. For shocks, I chose with King 2.5" coilovers with the compression adjuster knobs all around as Kings have been the leader in the business since I can remember. These are the OEM bolt up type that replace your front struts and do not require any fabrication for shock hoops.
Once I picked up the truck from Baja Kits I immediately drove it to an alignment shop before my 4hr drive home. About 20 minutes later they called me and said no alignment was necessary..... it was spot on! Incredible; between fabrication and installation they were able to keep it all aligned with zero correction after install. Overall the ride is MUCH improved! Obviously stiffer shock valving than stock but not jarring at all. I feel like it's a good in between feeling of my 2005 Duramax 2500 and the stock form 2019 Silverado 1500. So far I've only smashed a dip in the road but even just that was handled amazingly and beyond my expectations. I haven't had the opportunity to take it off-road for a proper feel but that will be coming soon. Currently the compression adjusters are backed off as far as they'll go so I have plenty of dampening room for off-road bouncing.
Feel free to ask question or visit Baja Kits website  https://www.bajakits.com/  or instagram @bajakits (they do not have my kit listed yet as this was their prototype kit) and tell JT that Cody sent you. They should be releasing the front end kit in the next week or two) and always offer just the King coilovers that you can bolt onto your stock setup.
Dang ?!!!!
Thats a proper set up. Any idea what they are charging for the LCA’s? What’s next? Prerunner bumpers?
Wait... is that a long bed?? ?
edit: nvm haha, I see someone stated it’s a standard.... wow, don’t see very many of those
Edited by TheTicketTX
On 2/26/2020 at 12:29 PM, Ryguy said:
Dang ?!!!!
Lowers are going to run around $2000. I already had purchased the uppers on Black Friday. Yes to prerunner bumpers. I will try and keep these as clean and daily-driver oriented as possible. I might not be able to get rid on my rear bumper as I'm completely sold on the steps on the ends and would hate to give them up.
Edited by code-man26
Not a long bed, just a real sized short bed unlike the "stubby" short beds that are the fad lately. I had to wait and search for this combo (crew cab with a standard 6 foot bed) as the salesman said that less than 4% of trucks come with this combo. Still haven't seen another one on the road.
18 hours ago, 175vTrailbossLT said:
Bump need full truck pics!
I know, I know. LOL, Realized this after I posted. ?
Photo shoot scheduled today at the beach (I live next to Oceano Dunes OHV Park).  Will get some full truck pics as well as action shots.
I have std bed and was told same thing.....fleet manager took 2 weeks to find mine.
your truck will be proper offroad vehicle...raptor has nothing on you
3.0 bypasses next time. lol.....you already shown the pics that matter and that is the way to do it for sure, if your gonna spend the money that's better than lift kit by far anyway you look at it
so if you get 3' lift from the control arms and the kings are adjustable what are your options for height, I know you don't need a ton.....baja kits says you can run 39'' tires with this kit and 40" if your willing to trim, am sure front bumper being limiting factor....
trophy trucks really aren't that tall aside from tires ...tire size and lifts are bit misleading but you don't need 6 or 9 inch lift to throw big tires on truck...unless that's look you want
Edited by Dunn
oh yeah and most important how much travel did you gain?.....think ext kings give another inch on the down but for sure you gained more
Only gained what the cv shafts allow, keep that in mind.
Yes you are correct on the 'lift kit' thing. Geometrically speaking, a lift kit actually makes your truck more susceptible to damage/breaking. I thought about going with the 3.0 Kings with internal bypass but I'm really not going to romp this truck hard enough to need that. They are super Gucci though! ?
The standard short bed was tough to track down and I appreciate a longer wheelbase for offroading (more stable at high speeds).
Next in order is to finish the rear end with the Deaver U182 leaf pack and Camburg extended shackles. The leaf pack says 3" of lift but in order to keep my ride height I'll utilize extended shackles to compensate for the lift all while improving the suspension feel. After that; she'll be ready to bounce so 35's and fiberglass fenders all around!
First Woops.mov
I haven't cycled it and neither did Baja Kits get back to me about that question. I figure it'll be posted on their website whenever they release the kit.
true, but they're are ways around that....TB axles or aftermarket or even extensions
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
