29 minutes ago, Anakalypto said:
eFfing Old Rebuilt Dodge
Yea forgot about that ono lol. I remember that one when I was a kid.
First On Race Day
C'mon man, that was funny!
Seriously now, my biggest regret buying my 2015 is that I didn't buy a dozen of them.
Yea, I would prefer less tech and less plastic and less bean counting micky mouse cheap hold me together but given that what problems have I had in 110K? A pinion seal, $8, and a piece of plastic shroud that should have been metal 'ticking' on the flywheel. A $10 part that cost $120 install. I consider my early Honda's to be the flag ship of reliable and yet this Silverado has been no more trouble than the best of them.
Now some might say I got a good' n. Some may say I got a Tuesday truck. Some may say it was the luck of the draw. Maybe. But if any of that is true then I've had the best streak of the improbable known to man and its lasted over 50 years; spanning several manufactures and models.
Treat it and maintain it like it's the last one that will ever be built and IMHO....it WILL reciprocate.
I hate to admit it but I am almost there. I do still love this truck but it’s getting to me with all the trips to the dealer.
It was a great truck until 15,000km. It’s been in and out of the shop for the last 12,000km for brake issues, power brake issues, replaced ECM, replaced TSCM, replaced PSCM. Faulty plug on some transmission wires that caused the truck to stay in 2nd gear at all times (thankfully wasn’t the transmission like they originally told me). Just got it back yesterday fire it up this afternoon after work and get a CEL for emissions.
All makes have issues but this is more than my last F150 and Ram.
update!!
Got the call from my dealer that my 'replacement' rear came in and they will be working on my truck Monday, might have it for Wed!!  Waahoo I've be in a loaner or rental since 12-23-2019   3 months is totally unacceptable coming from a major maker.   ?
On 3/7/2020 at 9:25 AM, diyer2 said:
I get being mad, frustrated because your new truck has issues.
I was bashed in another thread because I made the comment the OP come on here to complain.
Seems like a lot of this to me.
Every point made here is valid but the whiners get old.
If you're complaining without a solution, you're a whiner.
Yes, the dealers can suck. A truck can have issues.
I have purchased some things I regretted but I fixed it and moved on.
OK, they weren't as expensive as a new truck but the point is I dealt with it and forgot it.
There are still a lot of happy GM owners and I'm one of them.
My used 12 Sierra runs good with no issues.
If it develops an issue I will not come here to complain.
^^^^^^^this^^^^^^^
"Anyone else regret buying a Chevy?"  that's the title, it's where the whining and venting happens.
                <<<<<<that>>>>>>
2 hours ago, wizard4878 said:
^^^^^^^this^^^^^^^
That was a ridiculous post by a guy driving a 2012.
I'm the guy driving the 12.
No more ridiculous than the constant whiners.
he still has some valid points,  at least in my opinion and I know,  opinions are like butts,  everybody has one and most of them stink?
People complaining because their brand new trucks repeatedly have problems that are largely unable to be fixed isn't whining. People are stuck with basically 2 options, live with the constant problems or sell the truck for a huge loss, not good options.  Lemon law can come in to play in some circumstances, but not often enough.
You say they need to fix it and move on, well that isn't an option for a lot of people dealing with these trucks. Glad your 8 year old vehicle is still working well, the newer ones have a lot of problems.
Also, if you are tired of people "whining", then you should probably avoid the troubleshooting forums.
Or just about any other thread in any of the T1 forums. Lol
    • Sir, economics doesn't have a moral compass. 😉 Just say'n.
    • One would think. BUT....This is what a Google search gives for the GM OLM system:    It doesn't measure oil condition save the highly indirect water temperature. It should measure oil temperature and as we've discussed they are not as closely related as one might assume. The algorithm is based on expected conditions at the end of a certain number of miles or revolutions. And sirs, this estimated value is not tilted in the engines favor. It favors the OEM's bottom line. There are no magical number of miles nor revolutions. No magical time limit. There is only what can be measured directly and only in the broadest of terms would the values used even come close to reality.    It samples nothing. It has no idea where the oil started or where it will finish given the limited values use to create the algorithm. It is just a reminder for the brain dead to do something at some time to keep the warranty in tact. Pure fiction.    Key Factors in Oil Life Calculation The OLM calculates the remaining oil life percentage based on the following factors: Factor Description Engine Revolutions Tracks the number of engine revolutions since the last reset, decreasing oil life with use. Mileage Since Last Reset Monitors the distance driven since the last oil change, capped at 7,500 miles for most models. Time Since Reset Decreases oil life over time, dropping to 0% after one year, regardless of mileage. Engine Temperature Adjusts oil life based on coolant temperature; exceeding 260°F sets oil life to 0%.
    • Towing power and I guess MPG matter that’s why I may end up going with a gear swap as soon as they’re available for this truck if I’m correct
    • If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.   Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis): Sierra Pro (Work Truck/WT) Elevation (Custom) Elevation Premium -or- Ultimate (Silverado) AT4 (Custom Trail Boss) AT4 Premium -or- Ultimate (Trail Boss) AT4X (ZR2) Denali (High Country) Denali Ultimate (N/A) If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis: Sierra Pro (with a Graphite package upgrade option) Elevation (with a Premium -or- Ultimate package upgrade) AT4 (with a Premium -or- Ultimate package upgrade) AT4X (with AEV and Ultimate packages upgrade) Denali Denali Ultimate  Let's see if I'm close.
    • I have to believe there are already a bunch of threads on this, but my searches didn't turn up much. While I like the ease of a plugin solution like the Carbyte, It appears it disables the AFM or DFM too, and is not configurable to only disable the auto stop/start. So, I'm looking at the Autostop Eliminator product. I like the idea of it better, but I'm concerned about the install and having to pull so many panels to get it installed. Mines a 2026 work truck, so from what I've read it's a less involved install, but having watched a couple install vid's, I'm still a little intimidated. Might need to buy some plastic trim tools to get it done without breaking or marring stuff. Any experience intalling in a WT greatly appreciated.
