I just bought my truck last week and I am having the same issue.  Did you get yours fixed?  What was the solution?  I am also having a dead battery if I let it sit for 2 days did you have that issue?
  • Replies 57
Top Posters In This Topic
Any update on this from any of you about the solution? My 2020 Silverado under 4K miles just started doing this today. If I remote start the screen will stay black but if I just use regular push to start it comes on.... calling dealer tomorrow to see if they know of it. Also mine says no update
Let me know what you hear from your dealer I’m afraid to even let mine sit over night now it just started for me today after a trip to the store
Will do.  I see several people saying it’s a battery issue. Hope that’s all it is
Thinking that’s what it is noticed on star is disabled too and auto stop works less. I have app Saturday morning let’s see what they say
On 2/12/2020 at 12:21 PM, smiles said:
I have to park the vehicle, turn it off, and then re-start using the vehicles start button to bring the display back on. Anybody else having this issue?
About 1100 some odd miles on mine now and have not had this issue when remote starting.(knock on wood)  I am having almost every time I get in though where it is asking me to confirm which user profile.
18 minutes ago, Trtmntdude said:
Took mine in and they replaced the battery. Problem solved.
Guess that’s what I’ll be getting Saturday morning when I go to dealer
I had this blank screen issue on my 20 rst, I removed both infotainment fuses and put them back in, haven't had the issue since.
Auto stop has quit working today and noticed truck took a little more hmph to start today thinking it’s a battery for sure which sucks and weird for only being 3 months off lot
My 2020 2500HD with 500 miles is in the shop today with the blank screen on remote start, dead batteries yesterday and several other wired things. Like gauge clusters bouncing and info screen behind steering wheel coming on after truck was turned off. Will let y’all know what this shop says.
Let me know what they say because All of the above is what mine is doing plus auto stop has stopped working too
Having read these complaints all summer, though not really experiencing anything myself yet, I just thought of an issue we went through with a ford. I just went out an looked and it looks like both the engine ground and battery ground attached at the firewall, may be attached to a painted surface. We had a new 2011 fiesta and after a couple months at start up, the gauges would go nuts and it wouldn't start. Left her stranded a few times. Having dealt with with weird guage activity with an earlier grand cherokee, I figured it would probably be battery related. I went online and found ignition switch recalls and tech bulletins on the fiesta line for the instrument panel acting up and potential dash fires. The tech bulletin that seemed to cure everything, said to scrape away the excessive paint at the engine bay ground attachment points. I took a look and ours were almost completely painted over. Scraped them off and never had another tissue. Taking a look at mine, without disconnecting yet, the actual screws don't look to be painted, but obviously the surface of the firewall they but against is. I have a custom, so fewer electronics to boot up at start up, so maybe that's why I haven't seen a problem yet. I do plan on adding upfitter switches and some other stuff soon and plan to disconnect the ground straps and clean off the surfaces to prevent problems. I also have a short cmutr, so I'm careful about letting it run a little longer after starting to keep the battery topped off. All the control modules new vehicles have, use a lot of juice when booting up, aside from the starter. And then there's the weird, hit the locks again, then hold the remote start button for 5 seconds for the vehicle to fire and fan blowing full blast, using up additional juice at start up.
Edited by Stand By
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
