I finally got around to doing this upgrade to my '20 Elevation. The OE LED AT4 tail lights came with cut harnesses. You can unplug the cut harnesses and secure the new ones. I purchased mine from Ebay, OE LED AT4 harnesses. I added the Gen5diy and secured the built-in resistor to a metal surface as instructed. (see Pic). Everything works, and the upgrade is so worth it. ec48e7bdbc4370300cb4d9001feab606.jpg318b81e4661b778877a489affaff6595.jpg3cb08b8f2362f74bd6afda4e558182eb.jpgf3a8c2c3a5d23f3d0c2a4913a24dd13b.jpg5627cb0e9ae030e0448a8303204605fc.jpgeb8d521e93b764ab84c604e31119a085.jpg
Keep an eye on those resistors from Gen5DIY. Looks like you heat sunk them well like I did, but both of mine still failed within a year on my 2016, one right after the other. They sold me an upgraded set with two per side and they held up better but it’s a pain in the butt. They get really REALLY hot.
Will do... These are 1000w resistors so I'm hoping they will take the abuse. Thanks for the heads up
That's a typo above, should read 100W
just replaced my front turn signals with the ones from Go Performane I am so impressed both with colour and intensity I have also purchased two sets for the taillights as well. Hoping to get those installed tomorrow.
I replaced my front turn signals with a set from Lasfit and they're awesome. After installing I was surprised they let something so dull leave the factory. Best part is built-in resisters so no hyperflashing.
Have you done your tails yet, i just replaced mine as i wanted them to match the blade light bar, very strange condition from them. The tail/ brake and 4 ways work fine but when i put the turn signals on they flash at normal speed 3 times and then speed up (hyper flash) and of course the DIC in the dash says that there is rear turn signal bulb failure.
I purchased these because they are CANBUS compliant but the only solution i see is to add in resistors which negates the point of getting them, either that or put the dim originals back in?
My tail are LED from the factory so I haven't messed with them. It's strange that you're having those issues with the CANBUS compliant bulbs. Maybe have a dealer reflash your truck to a model that has LED tails from the factory?
Here is the video and the bulbs I used.  I dunno why you'd want to go in from underneath removing screws on the wheel well cover.
This video covers the turn signals going in from up top with no tools, and your license plate lights.
https://www.amazon.com/dp/B07Q8RZRZV/ref=cm_sw_r_cp_apa_fab_CtjCFbYKTN1YE
Edited by fsuboy75
I just installed LEDs in the tail lights of my 2019 1500 however I am getting hyper flash, I have load resistors but which wires in the rear am I supposed to splice into? I don't have a tool to check for power :( It looks like I have 2 black, a brown, and a green wire. Help? Thanks!
Definitely a resistor based issue, I tried just changing x1 and same results so I have put the originals back in for the moment. Strangest thing is that with the LED bulbs in that they flash 3 times then hyper flash I might yet consider the Recon assemblies, I see one of the guys has installed them recently.
Edited by Comscan
I just swapped mine from halogen to LED tail lights on my 19 Silverado just tap to the green wire and black wire coming from connector coming from the tail light
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
