The dealer is now installing the 3rd infotainment center XM radio since the truck was purchased new on January 26,2020. Has anyone else had this problem or similar? Thanks in advance.?
I'd be documenting this, keeping receipts, how long it's in the shop each time they're replacing it as this could give you teeth later whether it be possible lemon law, warranty extension, class action, etc.
I'd call GM direct and ask if this is a known issue and if not then suspect something in your vehicle may be causing these issues. Have you had any aftermarket accessories installed at the dealer or any other shop?
Could be a bad batch of radios but then GM and quite possibly the dealer would be seeing the issue.
If all else fails Google something such as "infotainment radio failing in 2020 ____ _____ vehicle and see if others are complaining elsewhere, etc.
Sent from my SM-N975U1 using Tapatalk
I've had tons of problems with my infotainment, unfortunately they are very random and cant get anything done about it
I would start looking into lemon law, but not sure what the criteria are for these systems.
  • 7 months later...
Just took delivery of a 2021 2500 HD All Star Edition and the infotainment system just quit on me.  I checked the fuses and they were good so I scheduled an appointment to bring it in.  Then it came back up fine the next time I started the truck.  Now I see that these systems have been causing problems for years and there is a class action lawsuit on the 7" screen....but the 2021 LT has the 8" screen.
I have a  2020 Custom crew cab with 7 inch screen , I just had it since august 16 times he radio has failed on me 4glte , direct usb connection  andriod or apple. i brought to the dealer twice for it.  The second time the radio erased everything while they where working on it and then asked me if i had another car to drive ,because the need to call gm and rip the entire dash off to check all cables,connections and box under the glove box.  They dont know how long i will be without it.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
