2018 Sierra SLT Ignition Lock
What is the problem with the 2018 Sierra SLT that occasionally when you put in the key and try to turn the ignition on, it won't budge? For a second there I was scared that my truck died, but it finally worked after turning the steering wheel slightly and then turning on the ignition.
Sounds like the steering wheel is resting on the lock so it won't release unless you take the pressure off by moving the wheel some. It's normal and won't happen if you don't lock the steering wheel when you shut the truck off.
