2 hours ago, Beastland said:
Sweet! Congratulations man! Whats your first impression of the interior?
I like the hell out of it. Can't wait to see it in person.
1 hour ago, goosehunter said:
What's your first impression of the interior, i have an LTZ on order....thanks!
It's sharp. I bet you will like it. I'll report back once I see it in person Friday.
My Denali should hopefully be delivered to the dealership within the next week, ETA shows 3/24. I’m told that it should be one of the first three that arrive at the dealership. I ordered the last week of January and production week was the week beginning 2/28.
Denali
6.2
Black/Black
Denali Reserve Package
Painted Wheel Arches
Had ordered an LTZ 6.2  and build was the week of March 7 and just got a VIN#  today from dealer......6 weeks wait time. I'm in NE Canada.....
                                                          GH
So accepted for production, and actually starting production are two different entities. Correct? After I was notified on 2/11 that my order was accepted,  I haven't heard anything. They said they would keep me updated.
Yes, completely different things. Just because it’s accepted (by GM) doesn’t mean that it has been started or even scheduled for production.
Edited by Dirk13
That is a really great looking truck. You will have a lot of people looking at it where ever you go.
Also I thought the Ultimate Denali had a carbon bed standard???????
25 minutes ago, Ryan Tierney said:
Thought they deleted the antenna? Or is it just gone on the ZR2, High Country & RST models
Ive now seen real world pics of LT and now the Trail Boss with one.
Who said they deleted the antenna?
Question for anyone who works at a dealership or has had previous experience. I put down a deposit on a truck that the dealer had already ordered. I was given the order sheet and msrp was $67,500. Since then, the price for the same exact build has gone up to $68,800. Will they honor the msrp given to me? Or will they increase the price? I’ve been told since it’s a retail stock order that the price will be increased. Thanks!
I called my dealer yesterday asking the same thing and they said that my price once you place the order is guaranteed but mine was considered a sold order with my name on it
Edited by Aycock1987
They are supposed to honor it if it was a sold retail order. I have gotten the runaround with a previous order a long time ago because the window sticker that showed up had the new price and not the as ordered price. They ended up honoring it but took some bitching. The reservation email from GMC said it would be honored.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
