Purchased new truck in March. Got tired of waiting for OEM felt liners so I bought Husky ones from Amazon. Multiple irritations with those, needless to say I won't be keeping them. My local dealer called this morning and left VM. He said that GM is either slowing or stopping production altogether of the OEM felt liners. He also said that they won't get any in stock until mid-winter at earliest or possibly next spring (if ever). He offered a "hard plastic alternative" which I can only assume is the Husky. So, my question is this, if I spray CRC corrosion inhibitor (cosmoline) in there and then am diligent of washing out the wheel wells in the spring and touching up areas w/CRC again, can I get away with running my truck with no liners at all for 10+ years in Minnesota and be (relatively) rust free??
 Welcome  - The Plastic ones might be GM, (check part's Dept. )  like i had on my 2015 , before they went with felt liners . Plastic ones did a better job in winter- Snow would sly off.   Good Luck
Argument could be made that the liners actually trap gunk, grit, and salt places making it worse than no liners at all.
I don’t think the purpose of the OEM liners is to inhibit corrosion. I think they are just there to quite the ride.
If I were you I wouldn't mess with liners you could do something like this in your situation.  Rust-Oleum 248657 Rubberized Undercoating Spray, 15 oz, Black - Spray Paints - Amazon.com
I read in multiple places where guys say that the rubberized stuff is actually worse than nothing at all. Thought is that over time it develops "micro" cracks and then moisture, salt, etc eat away underneath the coating while on the outside it looks ok. Then when it finally does show itself, the damage is usually so severe that the rust has eaten most of the metal.
I (think) I'm just gonna maybe try to go without liners. I don't go off-roading and noise isn't too bad the way it is. Maybe if I stay on top of keeping that area clean from dirt, salt, etc I'll be ok for awhile?
I would definitely install GM liners on the rear of your nice new truck. I did before they became hard to find/backordered. I ran a 2018 Silverado for about three years without them but I didn't keep it for 10 years. I have the felt liners and they work very well. I'm not sure where you are in Minnesota but I would try Luther Chev in Brooklyn Park. You could order them and use you Chevy Bucks if you haven't used them already on something else. Even plastic liners would be good if GM changes the material.
Fluid film is what you seek.  Same company has a newer product that doesn't smell like sheep as much - wool wax.
I had the underside of my 2018 tacoma sprayed by a local shop and when I traded it this summer there were only a few rust spots on the underside.  I live in NY so salt gets applied liberally in the winter.  You really need to re-apply ever year or two if you plan on keeping the truck long term.  I bought the kit and had a local shop with a lift apply it.  You can do it yourself but I'm past the point where laying on my back to save a few bucks is worth it to me.  Make sure to lower your spare tire carrier and spray that well including the rim of the spare.  You can probably access your front wheel arches from inside the engine bay - rears maybe the plugged holes where tie downs can get inserted might do the trick or remove rear tailights to shove the wand attachment in there.  The frame on these truck comes covered with a waxy substance already but I don't think it would hurt to hit the underside all over - especially inside the frame rails.  Just try and minimize any overspray on anything that gets hot and your brake pads.  Metal brake lines should get a good soaking.  The Fluid Film goes on wet and dries slowly.  It will attract dust and dirt but that kind of adds a layer of protection against water from blasting it off.
You can get a kit from amazon that includes a gallon of Fluid Film plus a sprayer with different attachments to get into tight places like rocker panels, wheel arches, etc.
https://www.amazon.com/Woolwax-Gallon-Undercoating-Bundle-Color/dp/B07QVH3PT8/ref=sr_1_9?crid=2RT2T6GXC36IQ&keywords=fluid+film+undercoating+kit&qid=1665624286&qu=eyJxc2MiOiI0LjYyIiwicXNhIjoiNC41NiIsInFzcCI6IjQuNDAifQ%3D%3D&sprefix=fluid+film%2Caps%2C107&sr=8-9&ufe=app_do%3Aamzn1.fos.d977788f-1483-4f76-90a3-786e4cdc8f10
I put the husky liners on my parents 2021 Silverado, I thought they fit just fine for aftermarket liners.
OEM liners were on back order in August 2021 so we went with the aftermarket parts.
I bought online from Amazon and read mostly good but some (not so great) reviews but went with those anyways as they were $50 cheaper than buying directly from Husky. They were labeled as Husky brand, but then had four "extra" holes down by the end flaps that were unaccounted for in the directions. There was also supposed to be 14 plastic christmas trees and I only received 12 to attach them (if you add in the extra holes, I was then shorted 10). The liners were too big and I couldn't fit in wheel well without some likely major cutting and/or modifications. All of which lead me to believe that they were some cheap knock offs or I was sent the incorrect part. Thus why I didn't want them on my truck. Worst part is, there's no free shipping to return and the post office wants $120 to ship (more than I paid). So I'm stuck with some plastic if anyone wants to make me an offer lol
Head to an auto dismantler, wrecking yard, pick-n-pull, whatever you have in your area and grab a pair out of a wrecked truck.
Back in 2019 when my 2018 broke down for the second time my dealer put me in an loaner 2019 LT (new Body Style) without liners. Every time the tires threw up a large rock it sounded like something vital flew off and hit the truck. One time it was so bad I pulled off of the interstate and did a walk around to make sure the truck was ok. I had the truck for 10 days and never got used to it. (my 2018 had liners)
When I bought my 2020 LT the liners were the first dealer installed option I checked.
I had Line-X Premium applied to mine when I had the box sprayed. Had them spray over the seams.
Between the box, and wheel tub above spray a lanolin based product. Blaster Surface Shield, Fluid Film, Wool Wax. Recoat once a year in the fall.
Nothing gets behind it and sound proofing is very good.
I don't use any but I live in Colorado where there is no salt used.  I just clean it up good when I get to town 40 miles away.  I don't miss rust from my Indiana days.
Depending on the undercoating or bedliner it may void GM's rust through warranty. I was warned of that when I declined their "protection package" and said I had my own protection I was going to spray on. I'm using PB Blaster surface shield. I put the Husky liners on mine shortly after I got it. They fit fine. They were a little tricky to get into place above the wheel well lip but fit fine and I had all the fasteners needed when I got mine. I HATE the factory felt crap and would love to replace the fronts with plastic if I could find it. The felt holds salt and dirt in and I've only driven it one winter so far!
Just a FYI. The GM rust warranty is a joke. When I told the sales guy that I was going to have someone spray the underside with cosmoline for me, he said that it would void the warranty. He then followed by saying that even if I didn’t do that, GM voids the warranty as soon as you leave the lot if you live in any state that uses chemicals to de-ice the road so I wouldn’t have a warranty either way. I couldn’t believe it, but sure enough, look at your warranty papers. Only in a handful of states will they stand by it. Arizona stands out in my mind but there were like 10 or so. The rest of us are screwed either way. Crazy
  • Sad 1
