Anybody else been told that the new trucks don't come with a manual in the glove box anymore?
My new 2500 HD didn't have a manual, just a small little booklet about the infotainment system.
Salesman told me they don't  include one anymore because all the information is in the menu system.
Yes
https://www.helminc.com/helm/product2.asp?Make=GMC&Model=SIER&Year=2025&Category=2&class_2=GMC&mk=GMC&yr=2025&md=Sierra&dt=Owner+Manuals&module=&from=result&Style=helm&Sku=87855255A&itemtype=B
$55 to get a paper copy.  Gotta keep skimming the costs down for the Generous Mother.  In their defense, I suspect you can find a lot of paper owner's manuals in junkyards dutifully stowed in the glove box of said junk vehicle with nary a crease in them.
I believe you can also download a pdf copy to your phone in the Chevy/GMC app.
  • Thanks 1
Being that your in the states it should be fairly straight forward to order one as per that link XY74 provided. It was an entirely different story because I am in Canada and many times the cost and I had one shipped but the shipping company threw it in the trash in Canada simply because I have a rural address and it took months to figure all this out but Helm was very kind to me and at their loss of the shipping etc and the book refunded me and suggested I order it through the Chevy dealer which I did and eventually did get the manual but with that same insanely inflated cost because of duty and shipping. The only catch would be if they no longer have the book your after in production or a delay due to having to do a print run on them.
Crazy they are not supplied with a $75K new truck. I ordered one off ebay, $57 shipped.
Correct.
They began phasing them out in 2023.  I "think" Corvette might be the only one left that gets a full manual included, maybe some Cadillacs?  They only provide a "getting to know your XXXXX" book, warranty booklet and if you have a diesel, the diesel supplement.
Its all online though, and its interactive.  You can click on the chapters and it takes you to them, and you can hit CTRL+F and search it quickly.
You can also access it in the MyChevrolet app on your phone if you have that set up, or in the MyChevrolet app in your radio screen and pull it up right in the vehicle.
Here's the manuals page from the Chevrolet website.  They have from 1993 to current on there -
Manuals and Guides | Vehicle Support | Chevy   This is by far the easiest and best method of reading the manual IMO.
You can buy paper ones on eBay or from Helm Inc, who makes all of those books.  $$$ from Helm though, usually $80-90 to your door.  Even $57 from eBay is steep when you can just access it online for free.
Edited by newdude
Luckily my 22 poverty edition came with a manual still. I guess I can call it a collectors edition. Last year with an owners manual. Haha
Both my trucks came with them when I bought them used, neither appeared to have been opened much.  I downloaded hte pdf's for them from gm, I find the pdf to be more useful, as searching and flipping pages is faster on the computer.
And for the new trucks, GM splits the info across multiple manuals, so be sure to download all the pdfs for your model truck
There is a recall for certain 2025 trucks for missing owners manual
More info here:  https://gmauthority.com/blog/2025/12/chevy-silverado-recalled-for-missing-owners-manual/
2026s.  Not 2025s.  And a VERY small number of trucks.
Affected vehicles:
Number of affected vehicles: This recall covers 169 Silverado 1500 units, 3,211 Silverado 2500 HD units, and 28 Silverado 3500 HD units."
Edited by newdude
I honestly cannot recall if my 26 came with a manual or not. I just automatically downloaded it. Id most likely be inside trying to look up something anyway.
On 12/11/2025 at 7:37 AM, customboss said:
Yes
No.... It all depends on the model one gets.. There is a manual that comes with.
My 2024 has a manual that came with it, as well as the other little book.
“Poverty Edition” - haven’t heard that one before. I like it!  I have used “Sensible Edition” for my base model 2004 Yukon XL. Its cloth interior still looks like new.
I looked yesterday and mine did not come with a manual. I downloaded it day one so no big deal to me.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
