When I do drive my truck to work the speed limit is 45-55. There are too many cops on my route to go much faster than that. I still only have 5K miles on my truck
Hey guys, the first thing on the list is an intake. I know I want a K&N but is there much of a difference in the series. For those of you who have them, what series did you go with? My mechanic friend I go to for everything says 57 series but I wanted some outside info. Thanks.
Hey guys, I got my new sierra a week ago. The 6.2 is amazing and so is the knowledge gained in these threads. First on the list is a K&N intake and a Magnaflow exhaust. After that a custom tune from Nelson this summer, because I can't get a response from BlackBear. Still in the break-in stage and still haven't really got on the gas :nono:
i got on the gas from day 1. i read about the hard break-in, and it makes sense to me, supposed to seal the rings better initially. Controversial but figured i would give it a shot. currently @2500k with no issues,
http://www.mototuneusa.com/break_in_secrets.htm
http://www.crateenginedepot.com/Start-up-and-Brake-In-Procedures-W106C46.aspx
http://www.mototuneu..._in_secrets.htm
http://www.crateengi...es-W106C46.aspx
Thanks for the links, I read them both. I can defiantly say I am too scared to break it in by running it hard. It makes sense, but I just can't do it haha :uhoh:
Wouldn't waste my money on an intake or exhaust mods for this engine as the two factory installed systems are about as good as it gets already.
You guys getting 12.5 mpg at 80 mph must be somewhere really cold, your truck is an NHT build or you have some mods done to it that have affected your mileage (tires/wheels/etc) because mine will still pull down 16 mpg flat at 80 in 35 degree weather but I'm just a Z71 and all stock so....... :dunno:
Leave the exhaust alone unless you are doing headers and muff(factory exhaust is awesome). I have ARH headers on mine now with a magnaflow 3.5" muff and it really runs like it should. Lots of low end torque that wasn't there before and overall it breathes better and revs faster with the addition of long tubes.
What part number?
What part number?
Magnaflow #12909
ARH long tube headers 1-3/4" with cats and y pipe.
Any difference between the new 6.2 and say 07-10 6.2?
I believe that there is a difference in the 07-09 and the 2010 -present. I'm sure someone will chime in but I think it has something to do with AFM like the 5.3's have.
I don't believe the 6.2L was available until 2009. Prior to that it was the 6.0 and I do know the 2008 did have AFM. I may be wrong, but I don't think there is any difference between the 6.2L from 2009 to current.
Correct in the Pickups the 6.2 was available 09-current
The SUV's had the 6.2 starting in 07.
I just got my 6.2, last week, honestly don't feel like it needs any upgrades. It is a beast.... Love it....
BTW- 2012 GMC 1500 Sierra SLT with NHT package
Plus all the speed camera's that are popping up everywhere!!!
Not sure how far you are from Fairfax,VA but if you've drivin through it you know what I mean.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
