Belt Squeak/Squeal - Observations and Personal Solution (warning, kind
I have had the serpentine belt squeak, and squeal on the truck for some time now. I poured over all the possible reasons why the main belt could be making noise and how to remedy it. A little bit about the test subject (whom name is Sally). 2006 Silverado with the 4.8. Mileage is 97800. Main belt replaced twice for wear and AC belt replaced once for wear prior to addressing this noise. I should have taken photos to show some highlights but I didnt, sorry.
I decided to do the 100K preventative maintenance schedule on the truck in hopes of having the noise go away. Items consisted of the following:
Radiator replacement (Slight gunk found in it)
Complete drain, water flush with a tad of cleaning and refill of the antifreeze.
Water pump replacement
All hoses replaced
Power steering pump replaced (had been giving a slight leak for some time).
Main tensioner replaced (it was the original)
Idler pulley replaced
Both belts replaced with a Gator back version.
Since I had all the components off at one point, the entire front of the block was hand washed, gaskets filed down and cleaned with distilled water. Front of the block was check with a simple 4 foot aluminum meter stick for trueness (you never know). Then each replaced component was reinstalled, seated and check with the same meter stick for trueness. All checked out, everything reinstalled and buttoned up. Truck started with no noise and was like that for about 2 days. Same EXACT squeak/squeal came back so all parts were rechecked, verified for trueness and actually swapped out (lifetime warranty on all of them) several times. Noise persisted until last night but I will get to that in a moment.
I must give the description squeal/squeal so that others can understand. Sally would start up in the morning (either by the remote start or myself) and have the initial squeak (intermittent kind). There were days when the squeak would go away when Sally warmed up, then there were days when the squeak would stay no matter how hot (I live in Austin Texas) or how cold it got. Annoying but I could live with it for a bit. There was no pattern found in 3 months that I kept a journal on the squeak.
The second noise I would get mixed in with the squeak (every so often) would be the LOUD screeching squeal that NEVER stopped. How to tell the difference: the squeak sounded like a chirp chirp and the squeal sounded like a cat being killed (I have no other way to describe it). Each sound was very distinctive and this is what had 4 shops scratching their heads. Squeak would go away, squeal would remain or squeal would go away and squeak would remain. They and I could never get Sally to shut it for more than a day (and that was after replacing the entire front end again (all belts and pulleys except the crank pulley). I would say that each shop did a superb job of workmanship and patience on trying to solve this annoyance. ALL the shops ended up refunding all the money that I spent (because they could not honor their guarantee to get the truck quiet) so I was out only the original cost of replacing the parts the first time (I did the original labor job) and left standing with Sally and her noisy self.
Last night, a carpenter was at a friend's house in the middle of a bathroom remodel and I pulled up with Sally to give a hand with the remodel. Carpenter comes out of the house right after I turn her off and asks a couple of people that were helping out with the remodel, "Who was making all that LOUD racket, this is a quiet neighborhood?" They all point to Sally and he goes on to ask "Who's beautiful truck is this?" I have to take ownership of Sally's problem and start her up for this carpenter. He hears the initial noise, then asks to pop the hood.
He then tells everybody to shut up while he listens to the noise with the hood up (freaking loud at that point). He then does a visual inspection of the front of the block and simply asks "This all NEW parts?" I tell him yep and he says "You run down to Home Depot to pick up some materials to complete the remodel, and I will tell you how to shut her up." I am thinking to myself "This guy is a carpenter, not a mechanic. All he wants is a free run to Home Depot..." but one of the guys sees me thinking and says "Listen to him, he has fixed all kinds of problems in the past for us. Hell, we will pay for your gas if you want to" and then proceeds to throw a hundred on the now closed hood. I say that I am game and so the carpenter gives me a list of things to pick up from Home Depot (an assortment of crap if you ask me but I ain't doing any real work on the remodel).
Come back and the half the neighborhood is standing around watching me pull up. They are smiling and I am thinking "What did I really get myself into?" Carpenter asks for all the bags, fishes out one of the bottles that was on the list and tells me to pop the hood. He already had painter's tape and two handfuls of paper towels. He takes off the belt, stuffs and tapes the papertowels behind both the idler pulley and the tensioner pulley. He then takes more paper towels and tapes them on the adjoining parts to cover them (intake, other pulleys and whatnot). He then sprays quarter second bursts on each pulley, front and back, spins them and sprays more quarter second bursts while spinning. He then waits 15 seconds, takes all the tape and papertowels off. He cleans up his mess and reinstalls the belt. He fires Sally up and she is quieter than a mouse...neighborhood erupts into laughter and a lot of "I told you so" erupts. I dont believe my ears so I drag the garden hose and spray a bunch of water (because spraying water on the front brought back the noise in the past) for nearly 3 minutes, to no avail. Still quiet. I take her on the freeway and punch that stuff (toll roads :) ) and then come back and spray some more water. STILL no noise so I figure, "It will come back after Sally has sat overnight, a good cold soak will bring the noise back." Caught a ride home and went back this morning. Started her up and NO NOISE so I go and look at this can that he bought from Home Depot:
http://www.homedepot...51#.UMyBgm-1WPs
There you go folks. After 5 months of swapping new parts, visiting different shops, paying loads of cash (and then getting it refunded), documenting and researching to no avail, here a carpenter fixes the problem with 6 minutes of his day. His charge: couple of beers and two burgers made his way. He did tell me that if the original parts were on the truck, he would have inspected the idler pulley and the tensioner to verify if they were clean, if they were not cleaned, he would have made me clean them and then spray them to shut them up.
If you have this problem, you just might want to verify your idler pulley, tensioner for any wear or play. If they are worn or have any play, replace them. Clean up the area and spray in VERY SHORT bursts. If you are like me and have already had everything cleaned and replaced, then this is all you need. Yes, I know that it hasnt even been a full day yet but I cant get used to the silence (yet). Next up, Airbag light *sigh*
- Cueva
Ha, Cueva got schooled by a carpenter no less :). I am happy with the results so far.
Glad to see this post. I hope it works on mine.
My 01 1500 has all new parts and still squeaks. It was not squeaking when I was still driving it daily back in the spring. The alternator was the last noise maker. I will try this repair on the bearings. I must clean mine since it has some miles since replacing the parts.
I may even have a can of the spray already.
Thanks for the info and a correct title to the post so affected readers and searchers will open / find some helpful tips.
Babyhauler
  • 9 months later...
Update: it has been nearly a year (ok, 10 months) since that squeal was gone. It came back this weekend after Austin had a good rainstorm. Got annoyed to say the least since I didnt move the truck pretty much all weekend. The storm was bad enough that GPS and in dash radio were reset.
After hearing the squeal, I checked the pulleys to verify alignment (they all checked out) so I was left scratching my head trying to figure this one out. Searched online and found a video suggesting to clean each pulley with carb cleaner and the scrubbing it with a bristle brush (for the grooved pulleys) and then using a little bit of steel wool to clean the smooth pulleys.
Took off the belt and cleaned that too with the carb cleaner and then scraped the belt grooves as well. Let the cleaner dry off and put everything back together. Quiet as a mouse. Dont know how long the silence will last but it was better than replacing parts....
Hey Rob, thanks. I am on my 4th tensioner (warranty replacement)....I have gotten so quick at swapping it, I can now do the swap in 3 minutes at Oreillys. The chirp came back this afternoon....very intermittent only at low speed. inspected the pulleys and they had a little bit of fine dirt. got to spraying, scrubbing and inspecting. squeak is gone again. I dont know if I am missing a plastic part from under the truck or what. Maybe another replacement and a through cleaning on all the pulleys (and belt replacements) will solve the issue.
I like the fact that the cleaning is actually working (nothing ever wrong with a little elbow grease).
Will keep this posted as anything develops.
i didnt read that the a/c tensioner was ever replaced ,,,,i know its not your trouble but they do take a crap
A/C tensioner: No, it is the original
A/C Belt: No, it is the original
a/c tensioner not accy drive tensioner,,,,2 belts on your truck
Lots of the LS1 guys use this to quiet belts and make them last forever:
http://store.katechengines.com/billet-belt-tensioner-p4.aspx
I have replaced the tensioner on my Trans am with acdelco because of the chirping, but if it comes back, I'm getting this. One time setup to tighten and it's good to go. They say your serpentine belt won't stretch without the use of a spring type tensioner.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
