Jeez. $350... why couldn’t GM just stick with the ole normal bulbs so it’ll be an easier upgrade path lol
An upgraded halogen bulb would be terrible compared to any HID output lol. Once D5S bulbs have been out for longer, cost will drop. They’re still relatively new.
Trying to find out information on upgrading headlights in this thread is so damn time consuming. There is so much information just spread out. I'm sure there are a few people who know almost every option and the ups and downs. So maybe someone knowledgeable could just quote this post and fill in the blanks and we can sticky it at the front.
Headlight upgrades
2014-2015 sierra slt/denali -
Good - $ - Morimoto HID upgrade- ?
Installation difficulty: 4?
Better - $$ - d2s 4.0 ?
Installation difficulty: 7?
Best - $$$ - fxr 3.0?
Installation difficulty: 9?
I basically made up the answers to this one for use as an example, the expert can edit
2016-2018 sierra slt/denali (upgraded led projectors)
Good - $ -
installation difficulty:
Better - $$ -
Best - $$$ -
2014-2015 Sierra non-hid
Good - $ -
Better - $$ -
Best - $$$ -
2016-2018 Sierra base headlights
Good - $ -
Better - $$ -
Best - $$$ -
2014-2015 Silverado projector headlights -
Good - $ -
Better - $$ -
Best - $$$ -
2014-2015 silverado el cheapo Halogen headlights
Good - $ -
Better - $$ -
Best - $$$ -
2016 - 2018 silverado high end headlights (don't know what kind they are, edit this)
Good - $ -
Better - $$ -
Best - $$$ -
2016-2018 silverado low end headlights (don't know what kind they are, edit this)
Good - $ -
Better - $$ -
Best - $$$ -
Good idea TruckGuy!
Seems this should help folks be able to decide on what lighting upgrades will suit their budget and ability to perform an installation or outsource the project.
Headlight upgrades
Good - $ -
Better - $$ -
Best - $$$ -
Good - $ -
Better - $$ -
Best - $$$ -
Good - $ -
Better - $$ -
Best - $$$ -
Good - $ -
Better - $$ -
Best - $$$ -
Good - $ -
Better - $$ -
Best - $$$ -
Good - $ -
Better - $$ -
Best - $$$ -
Good - $ -
Better - $$ -
Best - $$$ -
2016-2018 Silverado 1500s with LT lights - come stock with HID. About $1200 to upgrade to these. 5 minute install. Easy. Better.
2016-2018 Silverado 1500s with LTZ/High Country lights - come stock with LED. About $1400 to upgrade to these. 5 minute install. Easy. Best.
If you’re upgrading your 2014-2015 Silverado 1500 front end to 2016-2018, you will need the hood, bumper, headlights, grille, and grille shroud to make it work.
2014-2015 LTZ projector headlights are around $300-400. This would be an upgrade if you had the cheaper halogen reflector style headlights that come in the 2014-2015 LT trucks.
Adding H11 HIDs would be another $200 or so. Better. Installation of headlight would take 5 minutes. HID bulb and ballast install would be about 30 minutes.
Hope this helps, I have personal experience upgrading to the 2017 LTZ LED headlights as well as 2015 LTZ headlights with aftermarket LED bulbs.
On 10/24/2017 at 7:45 AM, FastWS6TA said:
For the Sierra? Yes. That code works. We don't sell the 4.0 for Silverado at the moment. Honestly would do the FXR over the 4.0 anyhow.....
Sent from my SM-N920V using Tapatalk
I have 2014 w Oem projectors was thinking of doing the 4.0 swap.   Heard they are better than the FXR and always according to light works what are your thoughts why do you like the FXR better ?
On 2/27/2017 at 5:11 PM, PirateDiesel said:
….does anyone know if the extended dust caps for the Silverado are still available? I see them for sale on Shapeways and messaged the seller but haven’t heard back in over a week. I completed a D2S 4.0 projector swap a few weeks ago and am currently running D2H bulbs so everything will fit under the stock caps (plenty of room with D2H bulbs) but would like to switch to OSRAM D2S bulbs which will require extended caps so everything will fit.
I have 14 Silverado 1500 that want to do this to.  How are you liking yours?
Finally did a fxr retrofit on a 2015 Silverado with factory projectors. Light output is amazing. Used the d2h bulbs and everything did fit under the cap.  It appears I am having issues with my cut off line. It looks as if one side is shadowing the other. The step isn't even, like there are 2 steps side by side instead of 1 distinct step in the middle. Tried taking pics but they don't show the 2 steps. Looks perfect in the pic. Lol  Any idea welcome. Thanks.
Love it.  Night and day difference.
On 10/29/2017 at 9:49 PM, FastWS6TA said:
Morimoto MLED Brackets for Silverado are all done. They fit great. No dust cap modification or anything needed. I'll get our website updated this week with them on it.84906ec0bd2a1df7515f648e3757ce37.jpgdaf1610e48991e693e99df0542e10290.jpg
Attempting my own mled retrofit in a set of replica projectors. 3D printed my own brackets, but noticed that the overall mled length from the mounting plate to the end of the lens is about 1/2 inch shorter than the halogen projector. Because of this, the projector sits further back from the trim ring and absolutely kills the side visibility. I also had to modify the passenger side dust cap to fit with the projector in.
My questions are: will your brackets work for this layout or is it strictly for the factory projectors? Do the brackets compensate for the overall length difference?
On 9/28/2015 at 11:57 AM, RobZ71LM7 said:
Amp Ignitor & Amp to D2S Adapter:
http://www.theretrofitsource.com/components/ballasts/morimoto-xb35-amp-hid-xenon-ballasts.html#.Vglic9JViHo
http://www.theretrofitsource.com/accessories/amp-d2s-ballast-adapter-90-degree.html#.Vgli6tJViHo
D2S Ignitor:
http://www.theretrofitsource.com/components/ballasts/morimoto-xb35-d2s-hid-xenon-ballasts.html#.VgliQ9JViHo
Notice the amount of space behind the bulb. I doubt the shapeways cap can accommodate a D2S ignitor, but can probably accomodate the former. But I could be wrong. I went with the conventional D2S setup for the ability to run OEM ballasts.
How did you solve the dust cap extension? Im good with drilling a hole for the grommet and wires, but how did you extend to clear the DS2 igniter?
Hey there. In am still working on the brackets to try and move them forward some. But as far as the dust cap goes, did you take the threaded shaft off of the back of the projector? It should be fit easily with that removed.
Use a d2h bulb. Then you can use an amp igniter and not those big fat d2s. As far as the cap goes, just get a heat fun and heat the back of the cap up so it starts go melt and u can stretch it out. I out them in a bench vise so the cap can sag down while I heat it.
Great Idea !  Do you have an example of you stretching out the cap?  Also i was leaning to get better bulb choices i really like the philips xtremem gen 2.  Outside of the different bulb options is the light output of a d2h better than h11 rebased HID bulb everything else being equal?  You might be able to talk me into an easier install.  =)
Thanks!
Has anyone retrofired any of the aftermarket housings? would they have the same mounting locations as the stock lights so that could use say FXR swap brackets?
I was going to retrofit my stock lights but i would really like to black them out and would rather just buy new ones instead of trying to remove the lenses on my stock ones to paint them
I was kind of eyeing up these ones:
https://www.ebay.com/itm/FOR-2014-2016-GMC-SIERRA-PICKUP-BLACK-HOUSING-AMBER-CORNER-PROJECTOR-HEADLIGHTS/202122435926?hash=item2f0f6f9d56:g:O0UAAOSwzppaFi-I&vxp=mtr
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
