I'm shooting for lemon or buyback. Hopefully this happens, don't want to take a hit on trade. Looking into Ram. I've never owned a Ram before, not even a Chrysler product. Will see.
Sent from my XT1053 using Tapatalk
As someone thats worked for Chrysler, I can tell you the most common issues are electrical,vibration with bigger tires was also seen, front end.
I'll look into those. I joined a RAM forum to get there input as well.
I say none of those exist on any I have owned - my last ram had 44s and ran true and the front end lasted for 62K with 44s. Never ran into an electrical issue NEVER and do not know any on DTW that ever cited that as ever an issue or vibration.
Maybe in Canada there may be some issue but I have not saw or heard about those in the states and I was a member of the largest mopar forum for years and still frequent it so this post has me somewhat confused. Only reason I came over to GM was I lost my local Dodge dealership and would have to travel 110 miles to complete anything that would occur, sort of thinking it may be worth the trip now.
Ant don't even look into a gm. We talked the other night. They have been jerking me around for 2 months now
Sent from my HTC One_M8 using Tapatalk
2 months, thats nuts. I drove the 3.0 ecodiesel, very impressed. It was the ST edition aka work truck. But I was mainly interested in the engine and trans during the test drive.
Yeah I have no idea what I m going to end up doing
There were issues with the factory 20s, electrical issues and grimlins inside the cabin were aplenty http://www.carcomplaints.com/Ram/1500/2013/ to see some common ones. Dodge has the same issue as GM when it comes to vibration, it was known to us at the dealership.
Im surprised you haven't heard of these, when you type ram vibration into google the 2 biggest ram forums pop up and you can see various topics on this.
PS: We don't have a different Ram in Canada, its the same truck.
Edited by Pinnacle
Those appear to be for older trucks. When I google 2014 ram vibration, I don't find anything.
Do you have an attorney working on it? A good attorney won't charge you. They sue GM for their fees. GM will screw with you as long as they can but when an attorney contacts them, they know you're serious.
Think that's the next step for me
That might be because there isnt a big enough sample of them yet.
Wow never knew this I have owned several and the last three had 20s? Maybe it was beginning with the 13 model year I do not know last one I owned was a 2011 and it was by far the best one I ever had
I would say the sampling is as just as large as the Silverado considering it has been outselling it for about half of the year
I owned a 2007 Ram with 20" rims...and that experience turned me away from Dodge forever. It rode terribly and was told the 20" rims just did that. I lost count of how many parts in the front end, steering, and suspension I had to replace. One day after work I started it, put it in drive and it wouldn't move... trans went. All this at around 50 thousand miles. It was gone a week later. I'd rather have a vibrating Chevy than a Dodge any day...they're all abotu cheap parts. Next purchase will likely be a Ford but I'll see what GM is like too at that point. Never buying a first year model again thats for sure...of any brand.
Well, there you go, it must be fixed.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
