Where are y'all buying tires after leveling your trucks? I spoke to 4 Wheel Parts (yes, I know that stink) and they were extremely adamant that 275/65/20 would not fit. I do not believe them due to the countless members on this forum that are running them. They looked at me as if I was crazy and said they would require a lot of cutting.
Just trying to find a store that will mount bigger tires.
Did you install the rear blocks with the kit? Are those the stock tires in the picture? I'm wanting to order my kit now, just trying to decide on what tire to buy.
X2
On any of the new body GM's you can put a 60 dollar 2 inch leveling kit and put on a 295/55/20 tire with ZERO trouble, iv got Nittos on mine in that size and haven't trimmed anything and haven't made any adjustments to fenders or anything, tell them just order the tires you want and if they feel like they don't want your money there's plenty of other tire shops that do
I know this question is asked all the time... And will probably get brushed under the rug... But I just want opinions on what tire size is best for fit, looks, and price for the truck. I was heavily involved in the car scene and decided I wanted a truck and there are a lot more factors that come in play with trucks. I bought a RC 2" leveling kit for $49 and I am installing soon. Won't be buying tires until I have the kit installed. I really like the look of the 33" toyo MTs but can't convince myself to spend the $400 a tire. I like the longevity and reviews of the ko2 but want a more aggressive look. Any opinions or input? In all reality... I drive city and highway and don't really NEED a mt tire or really NEED 33s, but like the same aggressive look. I will be using the stock 20" LT rims that came with the truck
Edited by Oklahomie
I have to KO2's and really like them. Once you get them on your truck they look more aggressive than you would think, and for highway driving they are really quiet.
Edited by PowderRiver Let'rBuck
I had a coworker install my 2.5 Rough Country kit today. I can not figure out if he installed the top spacer. I am measuring ~38.5 in the front and ~39.75 in the rear. I have also attached a picture of the threads of one of the top bolts. Does it look like the top spacer is on there?
Looks correct. You can't really see top spacer, as its thin. Also there would be threads showing if it wasn't installed.
It's on there can't really see it but there would be threads showing on the studs like stated before!
Edited by z71 chevy
I am currently in the process of deciding what rims and tires to get for my truck as well. I installed a 2" Zone leveling kit, and I am going to get 20x9 Fuel Hostage, and I finally decided to go with the Deegan 38. It has an aggressive look and is under $300 per tire, plus reviews are great for on road, off road, and in the rain and mud. i also like the look of the toyo MTs but the price puts them out of the picture. Good Luck
just got my Silverado the other week. this past Saturday night my neighbor and I installed the rough country 2.5 kit along with the new wheels. started around 8 finished at midnight. We took our time and enjoyed some silver bullets during the process. Love the result, exactly what I was looking for. seemed like a quality product and install was fairly easy. I have been wrenching on muscle cars since I was 15 ( currently 31) and this was my first "lift/level kit" had a few beater trucks in the past, always wanted a nice Silverado but could never ever live without a GM V8 car. finally got to a point in life where I could have both!
  • Like 7
Haha. Well neither is your incompetence, makes us even then. [emoji106] [emoji106]
Sent from my HTC One M9 using Tapatalk
Wow, you're a douche bag.
Anybody out there have or know if the Weathertech mud flaps will work with 275/65/20's on a 2.5" level ?
Thanks
I'd like to know this as well. Judging by pics it's gonna be really close, I have these mudflaps and am looking at putting the exact same size tires on.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
