I am wanting to run a 285/65R18 with stock wheels on a 2015 crew cab Z71. I'm thinking Bilsteins 5100 for the level. Can I run this setup at the highest setting or even the 1.25 setting? Not sure which height I want to go with yet.
sooo.. has anyone out there been successful with running a 20x12 -44 rim on a 33x12.5 with just a leveling kit? according to many people on custom wheel offset, it can be done with very minimal rubbing. is this true? I have been told that a 20x10 -19 rubs horribly, so does the x12 make that much of a difference, that you can run a 20x12 -44?
this is the day a brought her home,
and how she looks so far..
2 inch fabtec level, tinted tail lights, 285/70/17s sub and amp, and muffler delete
here is after i debadged it.
If anyone could chime in, I'd appreciate it.
I'm looking to see if a 305/65/18 KO2 can fit on a 18x9 with +20 offset using just a 2" level.
Thank you
Josh
here is an unedited pic after I debadged it.
Truck looks great! For your tinted taillights, what did you use? Laminx? It looks like the perfect shade to get rid of that bright red and still see the lights perfectly fine
I just did 2 coats of vht night shades on the face of the lights, and 3 coats total on the sides. My wife drives the truck alot, so I didn't want them to be too dark, and be dangerous. Just have to take your time and over prep the surface before you spray, and it turns out pretty good!
The taillights look black from about 15 feet away, but the visibility is very close to stock
Any quick recommendations for which particular brand or size of leveling kit I should go with on my new 2016 Sierra Denali?
I'm still unsure of any drawbacks to a leveling kit due to the magnetic suspension. Is this a concern? I just want the front brought up to where the rear is... flat and level. Thanks!!
I just did a 1.5in level ( under strut level) on my 2016 today. I have 2in of rake and couldn't be happier. It's looks perfect.
From Post #2720 on page 182 in case someone else is interested.
Finally, after 182 pages, I see someone is running 305/65r18s on stockers. Would like to know more about this truck and any clearance or power issues with those great looking tires. Or from anyone else running 305/65 or 305/60 on stock 18s with a level. Seems like a beefier alternative to 285/65s. I'm guessing it works because BFGs tend to run narrow and very square with little sidewall bulge (section width).
No clearance issues. No power issues, but I also added a CAI, exhaust, and a Diablo Tuner. My highway MPG with the BFGs and level was still at about 20mpg after the other additions. I actually no longer have these tires because the two rear ones got cut pretty badly (rocks on a trail I assume). For my new set, I chose to go with Nitto G2 285/75r18 (much better warranty with this size of tire), still have the stock wheels. For my next set, I will go wider as I liked the way the wider tires looked.
What are the specs on your engine mods? Like what did you put on for CAI, exhaust and which tune by diablo?
I'm eyeballing an exhaust and an airaid MIT
Possibly a tune as well, but not sure
Edited by tyrich88
CAI: aFe (51-74104) Momentum GT Sealed Cold Air Intake System for GM Silverado/Sierra 1500
Muffler: Borla 40359 Muffler (I apologize here, I said exhaust earlier when I really meant just a muffler, but I had them cut out the extra muffler and run 3inch pipe all the out way back)
Tuner: DiabloSport T1000 Trinity Dashboard Tuner and Diagnostic Tool
Next: Short Tube headers and Custom Tune by DiabLew
As far as CAI, I like S&B which I had on my 2007 Silverado, but at the time they weren't making one for the 14s (I think they are now).
Cool thanks!
I was thinking of the same muffler swap, I'm guessing your performance gains were pretty decent?
Cool thanks!
I put all of engine mods on the truck before the level and tires. I most definitely saw an increase in performance after I put the engine mods on, but of course after the lift and tires a little bit of that was lost. Hoping to regain that with the next mods!
    • I'm the original poster of this thread; I'm 85,000 miles now with no transmission issues after they did the fluid change without filter at 45,000.  I plan on a fluid change AND filter in another 5,000 miles and agree with you on staying to witness what happens if possible.  Ideally I would have done the filter at 45,000 too, but my original dealer was incompetent.  I've since moved on and get service done by another more reputable dealer, so I'm hopeful they follow the correct procedure at 90,000.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
