Haha no you dont, I definitely didnt take the axle out. The instructions that come with the motofab kit tell you how to install it. The bolt head is shorter than the nut so it makes sense that nut goes on bottom to maximize clearance. If the nut backs off the bolt is just gonna drop out as well.
HaHa. I see your point. I read another post from a guy that said he pulled his axle to get the the bolt in from the top so I guess I assumed that was the way. The RC instructions say and show a picture of the one bolt going in from the bottom and there is no clearance issue that way.
Well done. Not many people try that size tire with just a level. My buddy put them on his Tundra with just Bilsteins and they look so good. I've heard on stock rims that you're going to get a little swaybar and UCA rub without some negative offset (or spacers). Looks like 1/4" spacers does the trick. At full lock how much clearance do you have on the swaybars and UCAs. I'm guessing it's pretty tight.
It actually does rub slightly on the sway bar, but none on the UCA. I checked today after a few days of pushing it pretty hard and I can tell where it has rubbed a little.
Ok boys ....... What's the correct way to level this 2500?
Th 2500's use different leveling kits than the 1500's. You may be better off popping over into the 2500 forum and asking.
I would help, but i've never looked into leveling a 2500 since i've never owned one.
I'm thinking of selling my 3" Maxtrac Leveling kit that's just sitting in my garage. Anyone know what I should put it up for or anyone interested?
I've also got a 6" Pro Comp lift for a 2WD.
Edited by jnach
you happen to have any of your truck? not many on this thread so far of new body style w/ 2" level
A5D9B71D-05D1-42CD-AA19-5E5728C04CEE_zps
This is really all I have at the moment. No changes except painted emblems. Tires and possibly wheels coming soon...
thats just a 2" front level? nothing else in rear?
Hi guys. I just ordered a 2017 Sierra. Can you post what your CV angles look like with a 2 inch lift? I'm curious to see how off they are.
It makes no difference top or bottom. You would need to pull the axle to get the bolt in from the top.
Not if you drop the ball joint as the instructions on the motofab website tell you.
Edit: didn't mean to dwell, just saw someone already posted about this as well. Apparently there is a slight difference between the Motofab and RC kits.
Sent from my Nexus 6 using Tapatalk
Edited by Sierra Jon
Can you clarify: 'slight difference between the Motofab and RC kits'? both are lower strut spacers with new bolts. What is different?
This is a 2" Motofab. Well worth it.
Nice truck. It's the look I've been looking for.
Do you have any rubbing with that setup or did you need to pull back the liner?
Did you add the moto-fab 2inch rear block? I assume that's the 1 inch lift to stock?
If you have time, what's the height at your front and rear wheel-wells.
Once again, very nice truck and thanks for any info you can give.
Klappy
Edited by Klappy
Did you add a taller block in the rear or is it stock height?
If you have time, what's the height at your front and rear whee-lwells.
Klappy
Thanks!
It's a Motofab 2" level kit in the front with the 2" block in the rear. Also have Hellwig 987 helper springs which lifted the rear about a half inch.
I don't have measurements at the moment but in the end it raised the front by 2¼" and the rear by 1½ so I lost ¾" of rake which seems perfect to me. Tires are 275/60R20 Duratracs. They did rub the carpet and I was shocked because I read that this size was safe even at the stock height so I can only attribute it to the aggressive tread of the Duratrac tires. There's a pic I posted yesterday of the trimmed carpet liner - I did not want to use zip ties. Thanks again for the compliment!
I need some new pics but...
I was specifically referring to the installation instructions. Motofab is a top down bolt installation and requires you to drop your ball joints to clear the CV axle during install. it sounds like RC is bottom up. Also RC is cast steel and Motofab is machined aluminum.
I can only speak to the accuracy of the Motofab info I'm posting as I don't have the RC.
Thanks!
Sorry to keep asking questions. I don't see any pics of the trimmed carpet on this forum from yesterday, or the past few days. I even searched your name. Sorry if I sound like a stalker. Are they posted somewhere else?
I agree, I'm shocked too to hear it rubs, even if just a little. Not what I've been reading about 275 60 20's. With the trimming, would you do the same size tire again, or go down to stock 20's in a Duratrac?
Thanks again,
Klappy
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
