I know people say more than 2.5" is bad for your suspension, but I had a very similar set-up. I had the Rough Country 2" lower strut spacer and the Bilstein's cranked up to the max height, which put me at about 3.75" up front...I didn't have aftermarket UCAs, though I would have added them soon had I kept the truck. I had 285/75r18 Nitto G2s with stock rims and I was off-road quite a bit and no issues. I didn't keep the truck long-term and traded it for a 2500 at about 50k miles, but I had zero issues with my set-up and loved the way it looked.
2.5 isn't a magic number, anything over stock is bad for your suspension just the higher you go the worse it gets. 1 inch is worse than stock, 2 is worse than 1 and so forth. Going that high really pushes the limits of safety and durability or stock components that weren't designed to ride at that level.
Anyone know of the biggest size tire I can fit on a 2" leveling kit 2wd silverado. I'm wanting to go with a 20x10 -24 offset.
TexasSilverado16
Have you tried searching yet?
Tyler
Tyler
Yes & I'm getting mixed answers of a 285/55 yes completely & some saying it rubs just a small tiny bit.
TexasSilverado16
suspension Maxx is a Great kit, made in USA and is the only one (i think) made for the magnetic ride in the denalis. without a denali they are still a great kit and easy to install.
TexasSilverado16
You have to research the tire brands too because it all makes a difference. I went with a 275/60R20 and didn't find anyone that rubbed with that size but my Duratracs rubbed the carpet.
Sent from my Nexus 6 using Tapatalk
But what size wheel setup did you use?
I want a 20x10 -24 off set.
Using a 275/55 would be like factory style but I want just a slight bit beefier like the 285/55 or yes a 275/60 but unsure of which setup works with the wheel option I want.
TexasSilverado16
TexasSilverado16
275/60R20 Duratracs with 2" Motofab (lower spacer) with stock 20" rims. Idk the offset on them but many people have the same setup with a different brand tire and they do not rub. I was very surprised.
Stock 20's from chevy is a 20x8.5 with a +31. So being that I want a 20x10 & -24 it pushes it out further so it would be a completely different tire to fit. I went with a 2" motofab upper strut spacer & just looking for a perfect fit so I don't rub or have to do any trimming to get it to fit.
TexasSilverado16
Here's my 2017. 2 inch rcx level with firestone airbags in rear. 305/45r22 hankook dynapro on factory 22s attachicon.gifIMG_0218.PNGattachicon.gifIMG_0217.PNG
Good looking truck
2014 Chevy silverado Z71 DCSB w/Bilstein 5100 level
Good looking truck
You can go to 275/65-20 without rubbing. +15 offset wheels.
Man there are some sharp looking trucks with just the leveled system. I plan on doing a 2.5" front with a 3" rear block. Just don't quite know what I want to run for wheels and tires yet.
Havok H109s 20x10's or 20's GMC Sierra Stockers...
Hello all, just got my 2014 Sierra 1500 looking to do a 2" or 2.5" leveling kit and need some recommendations. I also tow a camper and was looking to putting airbags in. Has anyone done both and what brands have you used. Thanks for the help
I have a RC 2 level with rear blocks and airride loadmaster 5000 airbag kit.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
