I’ve been contemplating it, I’ll have to wait and see the drive quality with these. I’m debating going to coilovers for now, I’ve spent to much time dealing with this truck, looking forward to reviewing what I’ve got and going from there. So far, I LOVE THIS LIFT, perfect height, just working at getting the best/smoothest ride possible especially driving in shit town roads Houston.
Sent from above
Taller tires = smoother, especially with 20s
You’re absolutely correct but I’m worried about these shocks as it is, adding more weight may negatively affect these 5100’s
Sent from above
Sent from above
Looks really good. I here ya on the shitty roads in Houston. I stay away as much as possible. I'm in the SW side of town in the burbs of Richmond. I'm either going with the same lift as you or Readylifts new 7 inch. Readylift says the track width moves less than a half an inch and minimal cutting for the install just like the cst lift.
Sent from my SM-G950U using Tapatalk
Thank you, it’s work in progress. My take on this lift today as follows. Absolutely awesome construction, nothing even comes close in craftsmanship, the thick welds, painting, everything about this lift is absolutely amazing. The installer came in the office today while I was anxiously awaiting delivery and I heard him tell the GM that he’s shocked at how much more stout this lift is versus all the others, he’s been doing this for 10 years and considered the best attention to detail installer. After I heard that I walked over to the wall and compared craftsmanship to a bunch others, ProComb, BDS, Superlift, Fabtech and a couple others and I immediately felt proud having this lift on my truck. It’s actually got extra brackets (that no one else adds) to help make the whole suspension 10X stronger all together. I’m now actually looking at getting completely new coilovers just cause you don’t want junk around this lift [emoji6]. All in all, it’s tru, you get what you pay for. There’s so much junk out there just to give you a lift look, CST is the best, ALL HANDS DOWN! Sorry, ranting on.
Sent from above
Sent from above
For the sake of discussion since you still have to test, my thinking is that more weight of bigger tires will add more leverage to move the stiffer 5100s, thus being more plush
That’s what I thought but in reality, the larger than stock tires I put on beat The heck out of the stock suspension until I put on Bilsteins but now even after I’ve completely replaced all previous Bilsteins with new ones the ride is noticeably much smoother than leveled just driving at regular speeds but a bit of tire hop going over rougher roads cause these Bilsteins get unhappy when they actually have to contain and control a heavier tire through this. This is why I’m now looking at coilovers.
Sent from above
Better put, these Bilstein 5100’s feel like they’re not in control when driving over bumpy roads but feel better than stock shocks driving on normal roads, if that makes any sense lol
Increasing unsprung weight has zero positive benefits.
In the case of ride quality, the increased mass means the wheel is less responsive to pavement irregularity.
Everybody get ready!
Awesome Black Friday deals coming
Sent from above
So the general consensus on the late model pre-19s is that you HAVE to get new wheels?  Personally I've been running 275/65/20 on my 18 with no level.  I haven't checked in awhile if I'm rubbing or not.  I would love to level it but all I keep reading is it will definitely rub if I do.  I haven't felt rubbing on my current setup.
I leveled mine as soon as I bought the truck, rode somewhat rougher afterwards then all hell broke loose as soon as I added the 275/60/20 KO2’s. Bought new wheels and tires and now I’m on a lift lol. You may be able to get away with the Adjustable Bilstein 5100 struts up front raised to, I think max 1.75” but couldn’t be certain. I wish I had someone inform me all this before I did the level, lessons learned, better off saving up for a CST lift and before you know it you’ll be riding up in style! Just a thought
Sent from above
Sent from above
I don't really want to go that big.  I am pretty happy with my larger tires right now.  I would prefer a level but not needed.  The larger tires I think helped out with all handling and I can't really tell any mpg hit.
Lucky you on the mpg’s. The leveling appears to more so affect those of us on 20’s. Word of advise, I very much dislike it when misleading information gets thrown around. Leveling is not a fix but a modification which unfortunately has caused financial grief to a good many “if not done correctly”. Good luck and Happy upcoming Thanksgiving Holidays
Sent from above
Dunno about consensus, but I’m running 285/65-18 (33x11.5x18) tires on stock wheels, leveled. Very slight rub at full lock, Nitto MT’s have very large lugs. I don’t believe (but don’t know for sure) that an AT tire would rub at all.
First, sorry if this has been covered but I either don’t use the search feature correctly or I’m just missing it.
I have the Rough Country 2.5 leveling kit installed by my dealer. The truck sits very nice with no load. My question is has anyone added Sumosprings (rear) to their truck? I do not want sag when we tow the trailer, it’s a 36 foot and yes I use a WD hitch. I just bought the 2018 Sierra SLT Z71 with 6.2 but have not towed with it yet. Will the Sumo help eliminate sag or is there a better solution? I am obviously assuming I will get some sag as it is configured right now. Thank you!
Edited by SS502
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
