Got it. Thanks for the info. Great looking truck btw.
Anyone know if I just put a 1.5 spacer with stock wheels and tires  if that will work out ok?
Im just trying to eliminate some of the extreme rake
You can do that and be just fine
Thanks
Thanks for all the help. Looks like I’ll get a minor front end level and stay with stock sizes tires. 95% of my driving is highway so not a big deal. Appreciate all the info everyone
That’s if you raise the rear as well when leveling.
You can add say an 1" to the rear and be totally fine on the factory shocks. If your going 2" or more you'd want to get the longer shocks but at that point your not leveling anything.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Adding 1” to your existing 1” makes it two, highly recommended to switch out rear shocks for having a 2” in the rear so you do not over extend the cheap factory shocks. Bilstein makes the 5100’s, a very good entry to medium level shock.
If you’re swapping the stock rear blocks (because you NEVER stack blocks) which are 1.25” for say a 2” block that’s only a net lift of .75”, for that you don’t NEED to replace the rear shocks. Once you start talking 3” (net gain of 1.75”) or bigger blocks, at that point you need to swap shocks
Adding a 1" taller block out back gives you 1" of lift over stock not 2". A 1" lift block is actually 2.25" tall if that's what your referring to but the OEM shocks are designed to work with the factory block. Sure it will ride nicer with Bilstein's but it is not neccessary for an inch. There was zero detectible ride change with a 1" taller block and reusing the factory shocks. I'm speaking from personal experience.
The Bilstein 5100’s are taller than stock shocks and that’s why they ride better than stock when you add to the rear block. My personal experience. I’ve only leveled one truck in my life and hated the ride quality.
I’d highly recommend anyone interested in leveling or lifting to consult an expert that does installs for a living as that’s who guided me to understand better fit and finish.
Or follow this simple guide:
- best ride quality & most expensive: coilovers
- cheapest: pick a spacer and throw it in, ride quality will not be as good as stock, but not unbearable
- budget: Bilsteins. They ride stiff, but the truck is more planted and takes bumps "better" (that's a very subjective statement)
- want a lift: CST, BDS, Or zone. Keep factory ride, or see coilovers section above
This will cover 98% of people on this forum. Do I install these for a living? No, but I do sit in front of a computer all day and have done more research on these trucks than I probably should have [emoji3]
That about sums it up 100%. Leveling and lifts are pretty basic stuff lol
You get what you pay for, Bilsteins are a great entry and way better than stock, stiffer. I’ll never use Bilsteins ever again after my CST lift and CST Coilovers with rear resi’s. Again, anyone can get the look, you get what you pay for.
My post outlines this exactly. For some, Bilsteins are perfect, for others (you and others I've heard from) they're not, which is why it's subjective.
That being said, not everyone has $3k+ to drop on a lift kit and coilovers like you did. I agree that your setup is the best of the best, but not everyone desires to spend that much on their truck just for the lift kit. Which is where the Bilsteins come in
And just to muddy the waters for ya...not all coilovers (or shocks for that matter) are created equal.
And, depending on who did the valving, you could have a good setup, or a crappy setup, even with the same brand and part numbers.
A King or Fox sticker on a piece of car jewelry isn’t a guarantee of anything.
I'm no expert but I have owned several lifted and leveled trucks. That being said I just don't want to spread misinformation about what is "needed" or what is merely an opinion about ride quality.
And, depending on who did the valving, you could have a good setup, or a crappy setup, even with the same brand and pet numbers.
That’s absolutely correct, to each their own. My experience is you get what you pay for. Anyone can get a lift but save up and get the best cause the look matters nothing as well as big shiny wheels. Ride quality is second to none with high quality parts.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
