I have seen the 20s run un +27 or +31. The replica all terrains I am considering are +27mm.
Sent from my SM-G950U using Tapatalk
I can get under my truck and look if you guys need it
Sent from my SAMSUNG-SM-G930A using Tapatalk
It doesn’t matter either way if it’s rubbing honestly.
There is a better pic of what I've got. Still some rake which i like. Thinking of doing an add a leaf or a 2" block. c49efb746df5251f3ae5e9a4ddb6d8b4.jpg
2” block replacing the rear stock and an add a leaf
Going with the readylift 1/2" hub centric wheel spacers all around with extended thread lug nuts. My local speed shop uses the same combo on their suburban with a 6" lift on 35 x 12's and they swear by it (only used to match width of front wheels). They have been in the game over 30 years so I can trust that. And as an engineer in my work we figure atleast 7 threads to be fully enganged, which is what this will provide. See pics.. Keep in mind the spacer in the pics was one he had in the back room to show me.
I did look into the steering stop that Zone offers B1188 that would be the steering stop part number, they come in the magna-ride leveling kits. The directions tell you to weld it onto the existing one. I am a fan of that and will keep it in mind. Not sure why they don't offer it as a separate part. Cool idea though. And wonder why its only in the magna-ride kit. 277e40260153d8a1ef8e1eb867ee1e6d.jpg285b7775e31cb55c498515886a80a489.jpg07b97f40587718c3546bb6818ecaef2e.jpg91cee6b97784147bc08ad43c93d38710.jpgeb7617417d9231a1c08a06f9a7e42e91.jpg
I posted this on a pic thread but figured I'd post it here as well...
Here's my 2018 LT 4x4 - she has a whopping 400 miles on the odometer.  The Michelin 265/65/18's were waaaaaaay too small so I went ahead and installed a Rough Country 2" leveling kit and a set of BF Goodrich 275/70/18's.  I guess I'm old school because I love the white letters.
you can get the steering stops separate. that is what i did.
Yeah I know. Zone told me to go to my local shop to get them. I like the idea. I found a nice set of 0 offset wheels (SCA, they build the black widows) that I will purchase when I need tires.. I would rather use the spacers for the time being as its "keeping it stock".
Traded in an 18 Denali for this 18 SLT. Had vibration issues that they just couldn’t figure out. RC 2” level with 275 60 2 Hankook tires. Happy with the look and even happier with the ride! No more vibration! 12AB1DE2-3143-444B-A892-6E36D150E19B.thumb.jpeg.bc207896e885440ddf783c106339d2bf.jpeg
‘18 All Terrain, 2” level up front, 305/50/20 Coopers on 20x9 et 0 (pic is with 300lbs of sand in the bed too).
Tomorrow I’m installing the Bilsteins set on the 4th notch.
Nice. What kind of wheels are those?
Ultra 107SB
.5" spacers installed with the extended thread lugs. No more rub! Will remain this way until I buy wheels. I am pleased with the fit up of everything. Of course, can't forget the fluid film. 4ba575eab94a8c6fb63b491677647259.jpg2ed27619dab92fb197b1b295ce60b106.jpgdc6974f028d1c564b6bc68f910346916.jpg
When installing the lower strut spacer to level your truck, has anyone just unbolted the bottom bolts, compress the strut and insert the spacer?  Is that possible or do you have to go through all the steps and unbolt the linkage, ball joints ect?
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,318 Guests (See full list)
