2 inch RC Level front nothing changed in the rear and 285/60R20 Ridge Grappler
before and after
Guys
I’ve read every single post in this thread, but I’m simply confused on what I need to do for my truck. I have a bone stock 2018 Sierra 1500 Denali Ultimate 4wd (22” wheels). I’m simply trying to raise the front of my truck up to level with the rear. I plan to keep the same stock wheels and tires. Can someone tell me what I need to get?
Thanks for the help. I’m not knowledgeable about vehicles and I need some help deciphering all the info I’ve been reading.
You end up pulling the trigger on a level yet? I'm in the same boat now.
I have a 2018 GMC Sierra 4WD that I had a locally manufactured 2.5 inch kit installed by a reputable shop which included 2” blocks in the rear. I love the new stance of the truck but now it has a vibration felt in the floorboard of the truck. Nothing through the steering. Any suggestions?
What did the shop say about it?  That's the first place I would go.
Are the rear blocks tapered? If they are straight that could be a possible source of the vibration since you are changing the pinion angle. I am on the fence with doing an add a leaf or a +1" tapered block from readylift myself.
Sent from my SM-G950U using Tapatalk
Sorry didn't mean to quote yours.***
before and after
Nice truck (twin).  You say you did the 2" up front only but in your signature you mention the 2.5.  Did you do the full RC 2.5 kit or did you do just the less expensive option and lift the front only?
I did go back to the shop and discuss it with the owner. He just blamed it on the change in pinion angle and stated that the new angle should seat itself after about 500 miles. He also stated that he had installed this kit in many other trucks with no issue.
I am not sure if the rear blocks are tapered or not. They were used rear blocks from another truck that he had performed a lift on. I think that I am going to remove them and reinstall the stock blocks just to see if the vibration goes away.
You can get tapered blocks from just about anyone. Look to see if if the rear blocks have a slight angle, looking from rear to front your rear blocks should have a slight angle downwards towards the front of your truck. Not having the right blocks will definitely give you vibrations and it’s an easy cheap fix.
Sent from above
Thank you. I will definitely check that out. Any idea how much of taper the blocks should be? I read on another post something about 2 degrees.
Pinion angles don't "seat themselves". That's just them trying to say they did nothing wrong. The block kit i plan to buy that I would recommend is in the pic. I used ready lift blocks and u bolts on my old Silverado with zero issue.
I would strongly recommend replacing the u bolts if you go with another kit as they have a tendency to stretch when they are torqued. One benefit to the ready lift u bolts is they utilize fine thread pitch, where the oem is coarse. The fine thread pitch has more mechanical advantage when torqued and will not come loose. The oem u bolts are prone to loosening (happened to me when i bought my truck, and numerous others on posts i have read). Good luck. 22de9080d6d8173928309dd27a89d8f1.jpg
It’s going to be more of a universal slope but most of all you should know it’s all going to be worked out. As soon as you can, take a side pic of your rear blocks. Where are you located?
Sent from above
I am located in Northern Florida.
Look for 4wheelparts, they’ll be available to help you. Call them and ask to speak with the manager, tell him you were told to contact them and get assistance with an issue. Don’t tell them where you had it done, just tell the manager your issues. IM me if you need assistance.
Sent from above
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
