Put my motofab 2" leveling kit in yesterday.  Took about 4 hrs, which included 2 trips to Home Depot for some missing sockets and combination wrenches.  I was able to torque everything back to factory specs, except for the top strut bolts (no way to get a socket over those) and the upper ball joint (again, no way to get a socket in that tight space).  Taking it in tomorrow for alignment.
I am VERY happy with how it turned out.  Before and after pics below (I didn't take the most flattering "before" pic...)
I’ve been reading and reading before deciding what to go with on my truck.. finally got it finished.. motofab 2 inch level, 20x9 Fuel Mavericks +1 offset, 295/60/20  (34x11.75x20) Nitto Ridges.  Minor trimming, Just barely rubs at full lock on the carpet.. nothing else.. love the look and the stance!
I was just thinking through my install from yesterday, and wanted to ask a follow up question here.  I loosened the top strut mount bolts a little, but only the bare minimum to be able to get the holes on the bottom of the strut lined up with the spacer control arm.  It took both myself and my father in law quite a bit of pushing/pulling on the bottom of the strut to get it lined up with the holes and get the bolts through.  Is there any chance doing it this way could have put some sort of off-axis load on the strut that could cause any issues?  (At least anything beyond what they will find during alignment...)  Should I have loosened the top strut nuts more?
Thanks!
Edited by malibu43
Great looking truck! glad to see no major rubbing or trimming, wanting to run a 34” tire on a 2.5” leveling kit here soon
With my 2 inch kit it sits 1/8 higher in the back.. you might sit a little nose high with 2.5
I’m almost dead even with my 2.5” coilovers. Just need to get some bigger meat in there, 33s aren’t quite doing it for me aesthetically
295-60-20's are your friend then!
Finally put on my 17in methods with 285/75/17 falken wildpeak at3w on my 2015. I have a 2.5 in leveling kit and rear is stock. Didn’t really need to trim but I did for ease of mind.
Hi everyone! I don’t post a lot but have an important question? I see a lot of ppl saying 275/60r20 works fine with a stock a suspension (no rubbing). I have an 18 with a 2.5 level and just ordered some BFG kos 275/65/20.....answers seem to vary but should I expect an type of rubbing? Wheels are stock atm.
How did you make out? Any rubbing?
Sent from my SM-G950U using Tapatalk
What all did you trim? Just the felt liner?
Yeah the felt liner and plastic cap. I cut the cap right before the screw that’s there. Also there is a metal tab I cut that’s behind the felt. I didn’t know if they would fit without trimming so I did it before I put the tires on. I just used a dremmel. I’ll upload another pick of my cutting tomorrow.
Thanks!!
Got my alignment done yesterday, so I'm good to go now.  The toe was quite a bit off, but everything else was in spec.  Again, I'm really happy with how the 2" level turned out.  Exactly the look I was going for.
If anyone has input on my question from my previous post, it would still be appreciated.  I'm still curious how much pushing/pulling/prying/swearing is "ok" on this type of project and at what point it means you're not doing something right.
edit - or do I have it backwards?  If you not doing much pushing/pulling/prying/swearing, then it means you are not doing something right?  ?
Edited by malibu43
3 hours ago, jgraves13 said:
Thanks!!
Idk why the pictures flip but that’s where I cut. Today I rubbed a little while backing out of my driveway and turning the whee all the way. I’m sure if I cut the felt up a little higher I would rub but I’m not. I spray painted the metal tab I cut and hit the edges up.
Thanks! Looks like a mini NorCal mod haha
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
