1 hour ago, Kman731 said:
Perfect, thanks. I think I'll do the 2" front and 1" back
So the 2.25" was too much lift for the ball joints?
The stamped steel uca’s are gm’s version of cutting costs. They changed to these 17 and up. If u have aluminum or forged uca’s, u should be ok. My 15 had aluminum and I never had a issue in over 100 k. These new ucas’ from Readylift have 1 ton ball joints for better articulation from what I am told.
I'm very happy with the ReadyLift upper control arms, really like the fact that you can grease the ball joint as well.
Well, here it is. My 19 limited. I installed the ready lift kit, 66-3086. Had my 275/65-20 ko2’s installed with a alignment done. The truck rides the same as stock, in my opinion. You do feel a little more of the road due to the e rated tires but it’s great. Feels more controlled than my 19 slt(new body style), which I didn’t like. I drove it home, cranked it full lock in either direction, over speed bumps and any other road imperfections that I could find. I can honestly say there was no rubbing anywhere whatsoever. I even have a set of husky mud flaps installed. It’s sits nice and level. I may ad the ready lift 2.25” rear block kit to give me back a little rake for towing and hauling. Overall... love it.
Looks great! I don't think I'd go with the 2.25 block, I have the ReadyLift 2.25 level with the UCAs and the ReadyLift 1.5 add-a-leaf in the rear , as the truck sits in this pic I have a 150lbs of sand in the bed to keep it from having more rake to it. Just my opinion, I think you'd end up with the same look as original just sitting higher.f2db4ad44b3f5e7267703f86af7e63c5.jpg5f7beb2f114a8b4cfce8600eb394c69b.jpg
Sent from my SM-G973U using Tapatalk
Kinecr, what brand/model are those nerf bars? If you don’t mind me asking
Rough Country, don't mind at all, got them on American Trucks website, don't remember model but they're the wheel to wheel version.
for those of you with larger tires on stock wheels and stamped arms..how badly does it rub?
i need tires before winter and was going to go with 285/60r20 on the stock wheels and then get different wheels in the spring.
Does it just rub at full lock? I am ok with that for now.
the truck is a 2017 high country with 2"front leveling kit
On 8/19/2020 at 7:33 AM, Vasa1 said:
No rubbing issues at all with my set up
you have the stamped arms?
it seems a bunch or people were rubbing with factory 20s and anything larger then stock tire size.
I had the stamped a arms. I installed the Readylift 66-3086 kit.
Has anyone bought & installed these $8   2" front leveling spacers from Amazon?
https://www.amazon.com/AYNEFY-Self-Leveling-Suspension-Compatible-Silverado/dp/B08B8W8FKH/ref=sr_1_1?dchild=1&keywords=2"+front+leveling+kit+sierra+1500&qid=1598624039&sr=8-1
A friend is looking to do a 2" front level on his '16 Sierra 1500 and we found the ones above as well as several on eBay for $25-35.
Any forseeable issues by going with these vs. Motofab or other brands?
I stand corrected. I have some rubbing on the forward side of my passenger uca only at full lock going in reverse.
Anyone run the rancho rs9000 quick lift? I have the readylift 2.25 now but want to upgrade the shocks and figure its better to have less spacers. To make up for the .25 i found a 1/2" spacer that goes ontop of the coils for $19. Steel. I could go with the oem rs9000 struts but for the same price I can just get the coils and not need a spring compressor.
Sent from my SM-G950U using Tapatalk
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
