chas0218
Just noticed glitter like flakes on the ground behind the truck and all over where I disconnected the exhaust mid pipe from the y-pipe.
  • Replies 33
Cat is done
Sent from my Samsung Galaxy S4 using Tapatalk 4
Anyone have a trick to get their manifold collector flange nuts off? I have tried almost all penetrating oils and they still won't budge. Any other ideas? I have ran the truck to heat them up and nothing. Tried air impact gun, electric impact gun, I broke 2 breaker bars. I mean what else will get these things loosened up?
Ok so I removed the cats and they were shot. The ceramic was just bouncing around inside. I thought all was great and started her up and no change in the problem.
Question 1: Are my fuel pressure readings within spec?
Question 2: When I replaced the crankshaft position sensor would the code be cleared when I disconnect the battery and did not have a re-learn done? I still have the code. I also used a autozone sensor
Question 3: What sensors or gaskets are afiliated with the operating temperature of the vehicle?
Question 4: Would a severe vacuum leak cause this?
Thanks to anyone that can help. I am at a loss.
Today I am stopping to the dealership to get an OEM sensor and replacing the "New" sensor I bought from autozone.
Chas
Ok so I have an update. I cut the y-pipe apart and the ceramic was bouncing around inside, so they are shot.
I had a severe exhaust leak on both manifolds. So I started removing the manifolds today and have had to grind off the head of every bolt in order to weld a nut on them to remove them. It is slow going as I only had 1 nut that would fit over the stud and the closest store is 20 minutes 1 way.
Once I pulled the y-pipe and 1 manifold I decided to remove the O2 sensors. Here is what I found, the 1 with white residue and the damaged one (left 2) were after the cats.
  • 1 month later...
Ok update time, I got the exhaust fixed, no change so I took it to the dealership, they could not perform the re-learn because they engine would not rev correctly, they checked all codes and found #4 cylinder was misfiring constantly so they pulled the plug. They noticed it was fouled with oil and gas. They did a compression check and there is 0 compression. I also had multiple misfires on #3 and #5 but nothing they said it wasn't anything to worry about.
So it looks like I will be pulling the valve cover to check the spring, rocker arm, and push rod.
Well it was more of an issue than I thought, pulled the valve cover to find nothing out of the norm. I put a flash light in the spark plug hole while looking down the intake plenum. I could see daylight and there was no rocker arm attached. I pulled the head and intake valve and found this. Let me say that the square was checked on my cast iron table saw surface.
I think what caused this was the severe exhaust leak telling the engine to run rich which in turn added too much fuel to the mixture causing detonation in the cylinder while towing the large load. I hate to see this truck go as it was my first truck.
At this point I have had issue after issue with this truck. I will be trading it in shortly after fixing the issue. I have been looking at something a little newer and more capable of pulling our camper. I was astonished when looking at the towing capablilities and how much they cannot tow. I am currently looking at a 6.2L 2011 1500.
Ok so I replaced the intake valve and she runs better but once she is warm same story before she goes into "warm mode" or whatever its called. I am pretty upset that the inatke valve didnt fix my problem.
Could a bad throttle body cause this, does it use the coolant temp to change the fuel mixture? I forgot to mention that the dealership could not perform the relearn because of the issue going on. They said the issue is independent from the relearn.
  • 3 weeks later...
dang boy you were not kidding I love that picture of the cherry red cat. The engine sounds like it is shot, I doubt that anything you do now besides a total rebuild would fix your problems. How much for a nice crate engine to drop in there?.
Well now I have 140-150psi compression in all cylinders, I think the bent valve was from the truck running like that popping and sputtering. I have 2 new denso O2 sensors im putting in along with the simulators this weekend. I haven't gotten my hopes up on fixing this truck anytime soon. I am close to dropping a tree on it. lol
UPDATE so I was wondering would my truck run like the newly attached video if my injectors were bad?
Here are the numbers I got on my injectors.
Cylinder 1 18 Cylinder 2 26
Cylinder 3 18 Cylinder 4 24
Cylinder 5 18 Cylinder 6 16
Cylinder 7 22 Cylinder 8 30
After looking at these numbers could someone before me worked on the truck and put higher lbs injectors in? I'm not sure if that would account for the higher ohm reading or not.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
