After deciding the 2017 Colorado wasn't going to be enough to safely pull the TT we purchased, it was traded in for this 2018 DC, Z71, 5.3L and 3.42 rear end.  The color choice was a compromise. All you married guys know about "compromise", right?  AKA "yes dear".
This is it, plain Jane.  I added mud guards/flaps, spray in bed liner, Extang Encore Tonneau cover, running boards and towing mirrors.  It came with the factory break controller.
One year anniversary with it so decided to finally make a profile. Enjoyed looking at all these photos when making my decision on what to do with mine.
unnamed.thumb.jpg.eff2860ab7a0f97303478e67be48bfa4.jpgunnamed-1.thumb.jpg.1d3a14b8db758d493603595bb9015cbe.jpg
zone 2 inch leveling kit - nothing in the rear - 295/55R20 Cooper STT Pros with now 25,000 miles on them
What front bumper is that?  Good looking truck
Thanks. It is just the ranch hand. Was wanting one that could hold a winch but they were just all to big for a leveled truck.
Got this 2018 Silverado last week, it had 18,500 on the clock. Tailgate's been keyed already, drive out tags make it a target here. Got 100% of the dent and most of the scratch out. Little different than the 2010 Ranger I was in, it's like driving my den.
Edited by sheepdawg
8 hours ago, DominatorZ71 said:
2016 Silverado LT Midnight Edition
Bought with 21k and loving everything about it.0ef87ee2b55e547af4bee4423928922c.jpg9178659204e575083edc7b95dca00365.jpg
Congrats, looks awesome.....enjoy!
Just picked up my Denali and got a RC 7" lift with 22" Hostile Predators in asphalt with 35" Toyo RT open country tires. Flowmaster super 10 with turndown after the muffler, and 20%tint all around, think I'm done for now, time to enjoy
After doing speedy washes all summer, I was finally able to get a full detail in. Double bucket double pass hand wash, polished all the chrome, the wheels, and the exhaust tips, covered a few rock chips, and did a full interior detail. A two day chore, but it was worth it!
My 2014 GMC Denali 6.2. Bought it last spring with 14k miles on it. Put a RC 2” level kit on it. Plasti-dipped the wheels and emblems, K&N replacement filter.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
