4x4 not engaging
terryjsmith
Hi all,
I have a 2000 Chevy Silverado Extended Cab with a 4.8L engine. I recently noticed the 4x4 wasn't working; I can hear some stuff working but the front wheels are never engaged. I have had the truck for a couple months and haven't tested it extensively before this. It has an automatic shifter.
I've done some quick testing and when I lift the front of the truck, I can spin front tires manually when 4x4 is engaged. In 4LO there is certainly more resistance and I can hear/feel the gears switching and in both 4HI and 4LO I can see the drive train turning but not in 2HI (which I think is what I expect wrt to the drive train). I assume the front tires should not be manually turnable in 4WD.
In my testing, the pin on the axel actuator does come out and I can hear the shift motor working on the transfer case. I wasn't sure what it was (I'm still not), but I replaced the shift motor just in case and the result is the same.
So I've checked: the fuses, the axel actuator and the shift motor and now I am out of ideas an open to any last minute suggestions before bringing it to the dealer to diagnose. I understand there is also a control motor I can replace for another $100 or so in the dash but would like to know if that's likely to be the issue before taking any more guesses.
Thanks!
Terry
If you here the motors working then its probably something to do with either the actuator motor on the front diff. or maybe the little fork assembly that locks in the passenger side tire is shot. I'm no expert so I'm sure someone will chime in here soon. I actually need to pull my front diff. so I can get it rebuilt. Damn shop ripped me off
I had a bent mainshaft in the transfer case. I forget how much out of tolerance it was but on a lathe it was visibly "messed up". It caused the actuator motor to make noises but not change into any gear. The cause of that was the driveshaft yoke in the case had worn the tail bushing out enough to bend the mainshaft. I self diagnosed and replaced all parts though. Hopefully your issue isnt that serious.
A quick check just for the heck of it would be to get under the truck and try to push up and down, vertically or side to side on the rear driveshaft just where it meets the transfer case. There should be no movement in any direction. This may indicate the bushing just behind the black oil seal is worn.
sorry ,wrong info sir ,,,,you can move the rear output driveshaft of the tcase
Your right. The driveshaft slides in and out as it should. I was just saying other than that, I dont believe there should be any slop where the yoke spins around the bushing inside.
    • Mobil up another dime this am , $3.89, others will probably go up later. Any ideas on the reason for the increase other than greed? I've been working 14 hour days and haven't caught the news in a few days.
    • AMSOIL SS is about prevention and it is very good at it's job. I've never seen it claim to be a cleaner however like Valvoline R&P. Almost any oil that has some Ester or Alkylated Naphthalene in sufficient quantity will do a good job at keeping the rings functional.     I see the market splint among these types in two groups; those that use the same tech in every weight grade and those that reserve the tech for the EPA (EPA) friendly grades. Mobil 1 for example keeps the Advanced Clean chemistry out of the SAE 40 and up weights. Other like HPL (top shelf group and No-VII), Red Line HP, TORCO, MPT30K use the tech in all grades. Just not something the Wally World oils are into.
    • Max Trailering Package.  RPO code NHT.   includes 3500 HD Frame, 3500 HD Leaf Springs, 12" Rear axle and 3500 HD Shock Package.   GVWR goes to 11,750lbs for crew cab standard box 4x4, 11,900lbs for crew cab long box 4x4.  2WD crew standard is 11,500lbs, 11,550lbs crew long 2wd, and 11,450lbs on regular and double cab 4x4.       There is also NHT on 1 ton dually regular cab 2WD.  includes 3500 HD Frame, 3500 HD Leaf Springs, (F60) Heavy Duty Front Spring/Camper Package, 12" Rear axle, 3500 HD Shock Package, and Z6A Gooseneck / 5th Wheel Prep provisions with bed stamped holes and caps.  GVWR of 14,000lbs.
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
