First post, after a lot of searching...
Planning on picking up a RCSB Silverado, 2016, Z71.
Need to tow up to about 6klbs. Not opposed to helper air bags, but want truck dead level unloaded, with enough drop to be recognized, but still enough room for 22x10, -24ish offset, preferably a 12.50 mud terrain. Doesn’t have to be 12.50, but I want wide without stretch.. and with a strong shoulder of a mud terrain.
I think it’s on the outskirts of possible, with a little trimming, and think a 2/4 or 2/5 would be best option.
Problem is that I see some kits at 2/4 level, and some kits with 5” rear drop still with a ton of rake. I know there are tolerances and all, but on average-what rear drop gives dead level rear on a 2” front drop?
Or do you think this is unreasonable, and I should just drop the rear level and run 33x12.50s on 22x10 with stock front end?
This was my 2015 on a 2/4 drop with 22x10 wheels. I think the tires were 305/45/22 which is pretty close to 33x12.0 and I was already rubbing the fender liner.
With an even wider mud tire youd definitely have rubbing issues. I would do a simple reverse level, and call it good. 7b72bbddb68c25be5c0f20b88461ed5d.jpg
2" drop shackle and pull the leaf block and leave the front, it'll be dead level unloaded. I would be willing to bet that 22x10 with that offset and an aggressive tire will be close to rubbing stock so I can't imagine it'll work with a 2" drop up front.
2” shackles with block removed. And a set of homemade custom bracket for airlift bags. It’ll sit level with out without load!
  • Like 4
On 1/27/2020 at 2:10 PM, KEEPS808 said:
Yea when you order from atomic he asks you to measure the distance between the center of your rim to the bottom of your fender and he determines what parts he’ll send. That’s why I went with him instead of twisted.
Well, after much deliberation and mathematical equations using the formulas at the Viking website and Ridetech's coilover formulas I found out that our truck geometry calls for a 12" spring with 800 lbs/in for a 1" drop by spring... so, no wonder I am still bottoming out even running the coilovers at 17/15... I ordered some AFCO springs at 850 lb/in, and if the Vikings can't handle them I will buy Ridetech's coilovers and use the Vikings on the rear once I do the 4 link suspension.
As a side note, I did ran the 10" math, and they suggest a 1000 lb/in, but this is with the OEM LCA. I had no idea the LCA had so much influence on the spring rate of a car.
Damn man you went all in on that research and calculation stuff lol. Awesome. Tbh I’m not all that knowledgeable on all that. I just trusted them at atomic and hoped for the best and it turned out great. You sound like you’re on the right track for a smooth ride though! Are ridetechs better? I never read any posts with them in it.
To have the truck level, you need a 3" difference between front and rear. Almost every 2/4, 3/5, 4/6 drop that I have seen will result in a little rake. Here is a pic on my truck, it's a Crew Cab, and I have a 3/5. That's with a full tank of gas and some tools on the bed. Bed empty and it is more noticeable.
They are certainly better as far as that they actually asked you for measurements. I think Ridetech uses Fox's coilovers, as their main thing is Air Suspension. Their HQ's are around $250 each, no spring, but are single adjustable. Their 3 way run at $850 I think each. I have a very nice ride now, better than most cars on the road for sure. But after all the investment in suspension that I have done, plus the 4 link in the rear, that will not cut it. The fact that I am traveling down almost 3-4" hitting on the top of the inner fender metal on a coilover that is supposed to have 5.25" of full travel is not good. I bet once the 850lb/in go in I will see the 2-3" on compression I am suppose to have. That will stop me from bottoming out, at least on the highway.
Ridetechs are very popular on the muscle car scene, mini trucks from the 80's-2000, and HotRods. They have a few systems for fullsize trucks, but nothing for ours at this time. But since I already have the mounts for the Vikings, I can use those to mount their universal fit shocks, or I can reverse engineer them if I need to make them a little wider.
Edited by Maiden69
Yup I agree with the 3" difference front to rear in order to achieve a more level look. I am currently sitting at 2/4 with my truck and will be adjusting to 2/5 this spring for a more level look.
On 10/8/2015 at 8:57 PM, 07Softail said:
This is a 3-5 also
Nice truck..Should i run a cnotch with a 3/5 drop?
my truck 2016 reg cab silverado 2wd
I'm at 4/6 on my 2016 reg cab, no notch needed.
I have a 2/5 with no notch.
On 11/10/2018 at 7:21 PM, qwank said:
My truck with a 2/3.5 drop for reference
Truck looks great !! Getting my 2/4 drop installed tomorrow on my 16' reg cab wt. Might have to change my wheel/tire setup. currently running 20x10 -24, 295/45/20. so my wheels stick outside of fenders about 1"
Edited by cmb570
Looking for some info on drop and tire sizes. I’m thinking 24” reps and maybe a 305/35 or so tire, not sure how much I want to go down and look good but not be too low. My truck is currently lifted and just looking to change it up some anyone have pics of a 3/5 and 24’s with a 305/35 tire or something close?  Pic of my truck as it sits now
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
