6 hours ago, mike14 said:
So i’m about to get some BellTech lowering shackles for my 2014 sierra. My first time ever doing this. Any tips i should hear of? I’ve heard we need to return the shackles bolt torque back to spec, does anybody know what it is?? Thanks in advance!
Welcome to the site.
Here is a video for a NBS 19, should be same, looks like the instruction might have the specs.
On 6/15/2020 at 8:10 PM, Blitzfergie said:
Good evening everyone. I just bought a 2017 Sierra and looking for drop advice.
2wd/4wd stamped arms
id like a 2F/5R drop for a clean level drop.
From what i've read a 3" difference would achieve this?
my research shows the 1017SP kit would be what i need but thats a 2/4 kit. (2212FF x 2, 6700, 6525, 25004 x 2, 2514)
I was wondering to get the 2/5 im looking for would it be suggested to get (8510 x 2, 6401,6525, 25004 x 2, 2514)
basically swap out the 2212FF 2-4" drop shocks and change them for 8510 5-7" drop
and change the shackles 6700 to 6401 to get the 5" instead of only 4"?
also would it be suggested to get shock extenders?
thanks
Anything after 4 inch drop requires shock extenders I read. Also going from 4 to5 inch drop may require axle flip. It did on my 18 elevation.
Need some help.  I have an issue with the rear wheel/axle that I need help to diagnose and fix.  I have 2" drop spindles in the front and a flip kit for a 4" drop in the rear.  I noticed that the rear wheels have been sliding backwards since I had my truck lowered.  In addition to noticing how the rear wheels sit in the wheel well I also got underneath and the axle has shifted backwards versus the leaf springs.  Not exactly sure what is causing this but suspect I might need to shorten the driveshaft.  Pictures below show the rear wheels on each side and one of the rear axle sitting on the leaf spring being off center (though that can be hard to tell from the photo).  Is this something to be worried about?  What do I need to do to fix it?
You are missing a plate that holds the u bolts in place. And the u bolts are going the wrong way.  U bolts should open towards the ground.
See picture below of plate and u bolt orientation. Who installed the kit? A shop? If so I would get you money back or have them fix it because you kit is installed incorrectly according to your picture.
Edited by SlowGMC
Thanks for the help.  I did have a shop do it and I will take it back to them to get it fixed.
In looking more into the issue, the top plates are not to be found.  Since they installed the bottom plate on top they didn't install the top plates anywhere and did not return them to me with the other parts.  I have tried searching online to see if I can just find the 2 top plates but haven't had much luck.  I plan to try to call the different kit makers to see if any of them can help but figured it made sense to see if perhaps anyone in this group might have extras or a better suggestion for tracking the plates down.  Thanks in advance.
Edited by UofAZCats
Call the manufacturer directly. I was one time looking for a part included in the kit(i use belltech flip kit) and could not find it even in their website. I think that was the same part you are looking, U bolt Spring Pad Mount, part number 6521-004). Out of frustration, I ended up calling Belltech directly. And i got the part i needed. It was explained to me that the specific part, like the plate you’re looking, will not show up in their website but you can actually buy it directly from them.
Yea like previous guy said go to the manufacturer of kit and call them. Each kit is different and I'm not sure how interchangeable parts are from different shops on flip kits.
l recently purchased a 2014 single cab silverado truck with 2” inch spindles and springs with a flip kit that made it into a 4/6 drop. I wanted to fix my camber problem, so l was recommended these kit from beltech. The beltech part number is #4957. I had a shop put the part on and, I brought it to an alignment place and they said that they couldn’t put my wheels straight and my eccentrics where already maxed out. Any thoughts of how l could fix this problem? Picture shows how my truck is right now.
Are you sure the shop installed these correctly?
With just a 4/6, you should be dang near 0 as is or at least under -1
I would make sure they were installed correctly, usually the bushing kit should be rotated inward to the frame so it pushes the a arm out. The camber plate kit needs to have the factory slot lengthened to take full advantage.
Same reaction just like @sharkeysierra. My set up used is the Belltech lowering products set at 4/6 and had my alignment spot on. It did not require me to change or use an Alignment Kit (e.g. Front Camber Bushing). Nevertheless, wether you use same brand as I did or other else, a 4/6 is a 4/6 drop. I am now wondering, you even had an Alignment Kit added yet wasn’t able to meet specifications, I suggest it is worth checking again how the kit was installed coz there must be something wrong in that sense, what do you think?
I’ll go back to shop, l was thinking about probably they didn’t put a right bushing in or something. This is a picture after the shop installed the kit before getting the alignment done
Yeah, if they installed it, they didn’t do it right because the camber and caster are the same.
take a picture of your camber plates at minimum and post it here? The camber plates, the slot is supposed to be extended another .25 - .5 inch. I’m almost willing to bet they did not do this. The bushings May have had to be glued in, if not pressed in. They will turn if not done properly. I had a set of DJM camber bushings, they had to be glued in to stay. I thought I did it right the first time and after left the shop, before I got home the bushing turned on me and sucked my wheel in negative camber.
At 4/6, the plates or the bushings should get you into alignment alone and both together will get you far positive.
I do know when I was 4/6 with upper and lower a arms, the camber was within .1 - 2 of factory spec in camber.
Yeah they installed it wrong, and I want to say backwards.
AND
you are missing the pin the supposed to sit in that slot. I put a couple yellow dots where that pin supposed to be. 1494692F-7111-48C8-83D1-6DFFEA4FE078.jpeg.c1fa9145010aa00881db00de6da04f24.jpeg
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
