I have had my 2015 double cab for about a month and a half. I am well on my way to making it look like my own. Here's what I've done so far.
Husky Xact contour floor mats
GM bed mat
GM tailgate protector
GM underseat storage bin
GM black bow ties front and rear
AVS Aeroskin hood protector
15 percent on front windows
Iron Cross Patriot running boards
Truxedo Low Pro tonneau cover
That's all I have for now. I do have Zone 2" level kit for the front that I did not get on yet. I enjoy watching this thread to see what others have done to their trucks and get ideas for mine so keep the mods coming. Here are my pics.
I just installed 6k HID bright and dims in my truck last night, and honestly....I'm not that impressed. I like the white of the lights, but I was expecting it to be brighter. Are there different quality bulbs out there or is that just how it is? I even got the 55w ones hoping it would be brighter.
Drove 700 miles to enjoy a week in Georgia's countryside. Averaged 21 mpg cruising at 75mph the whole way. I'm pleased!
Drove her around town, first real drive since I got her back from the dealer. It feels kind of weird driving your truck after you don't drive it for a little while haha & of course I snapped a pic.
Installed my Go Rhino RB10 running boards today. Not convinced the line x type coating goes with my shiny black truck, but my wife says she likes it so I guess I'm good.
Got tinted all around. Llumar ceramic, air 80, matched the fronts to the rears, tinted the entire front also. The ceramic reduces incab temps by 50% and it makes a huge difference. Just got back from the beach in 100+ degree weather. With the truck sitting all day with the windows up, it was warm gettjng in but nowhere near without the tint.
Glad to see you are up and running again bud!!
Thanks bud! Feels so good to be back, time to start the mods again :cool:
Changed the oil, 7% oil life left at 7200 miles
How does it feel to have K&N filter in there??
Lol, more power, but no it's just a filter, [emoji20]
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
