finally got around to dipping my stock wheels black. im happy with it
Edited by beyondbasic
Alright, here it is, everything I've done today. Pretty busy but well worth it. Got it cleaned this morning at the local car wash (did a decent job).
Got back home and started off by replacing the front pads and rotors with Power Stop brakes and rotors severe duty truck and tow model
Moved on to the rear assist springs, easy install. Also hit the u bolts with the impact to make sure they were tight
Went ahead and covered the front and rear bowties with black vinyl, need to redo the rear bc I messed up cutting it so a little gold is showing
And last but not least I finally installed my bumper step LED's! This is my favorite of all the mods I've done so far, it just looks cool lol
Shot from the back with both lights on?
You just drill through from the step?
Looks good
Sent from my SM-G920V using Tapatalk
Looks good
Followed the removal instructions through Anzo for installing their replacement steps and I must say the bolts were a pain to get to. But yes, just drilled, reinstalled the step, and ran it to the cargo light wires. I'll get a shot from the back and put it up
Looks good. I want to do the little bowties in the middle of my wheels black. Have you considered that since I see your other bowties are black?
Installed the RC 2.5" leveling kit. Although the parking lot I was in is sloped to the curb and made the back look higher. I'm very happy with the results. Wheels will be in this week....
Installed oem High Country Grill today
good looking truck. LED running broads - Please explain ???
Thanks! Almost done. Ordered my 5th set of wheels today lol.
Led running board + bed LIGHTING
Edited by dbcooper
so did you add led strips above your running broads (rocker panel area) ???
Yessir. And wired to my dome light circuit that way it fades in and out when activated by remote
Also did the same in my floorboard areas inside too
Thank You. Looks good. I had recon BIG rig led strips - amber park/turn & led line of fire (last truck) . people saw be coming .
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
