ok so the led light behind the grill will be more intensive than i first thought.. . you have to remove the whole front basically.. . which i didn't have enough time this weekend to start...
anyone have any tips .. ?.. .. it looks intimidating....
Couple videos you can review before you start. I'm planning on doing mine Friday (been putting it off for a while). If you were closer to Houston, I'd say stop by and we both trucks.
double-post - delete
Edited by bgweed
word.. thanks yeah i did see the 2014 light bar install.. it was a good vid.... again, i can do it.. just more than i thought it was going to in tale.. i just need to take a day and start-finish it.. ... but its been so hot... i might wait till oct .
good luck with your install!...
Looks tougher than it really is. Took me 2 hours to install my lightbar with a wireless remote. Wasted the most time worrying whether I was going to break a clip....
its not that difficult. Other than getting the top bumper fascia off( upper plastic piece of bumper). If you got the rough country kit it's as simple as install a couple bolts on existing holes on the radiator core support. Good luck with the install!!
2015 1500 LT Silverado Midnight Edition
Edited by chrispassas21
thanks guys!!.. .. yeah i bought some longer bolts.. so i can attach it to the radiator supports... i'll drill holes through them... as for the switch.. i'm going to try and locate it in the cig lighter.... . i'll update this when i attempt and get it done.
Edited by Crstfr
you could do a wireless remote if that's what your looking for also!
Found an hour of free time yesterday and installed GM - Illuminated Door Sills. Love the way they look! Of course, made a how to video. The box didn't come with instructions and tried searching he web for some. Came up dry. So enjoy this How-To.
Part # 22933513.
Before:
After:
https://youtu.be/6vFuV9TAGZE
Edited by pgamboa
  • Like 21
Just got my BDS 6"lift installed new falcon wild peak MTs 35/12.5
Fuel Savage 20
Amp research steps
D badged
The BDS lift drives amazing feels exactly like leveled with 33's Falcon at
The MTs are at a little bit louder but definitely quiet for MT
No rubbing at all
Will post some pics on level ground tomorrow
Edited by Crazyfly
  • Like 9
Took her on a 3k mile road trip to Montana last week.
  • Like 5
Has been a busy few days but here is what I've done in that time. Removed air dam, replaced antenna with a stubby one, added Readylift 2.25" leveling kit, 20x10 Moto Metal 970s, and 305/55 Toyo AT.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Rolled over 50k the other day on the way to work. Today I installed some LED switchbacks in the front signals now no more orange unless i'm turning.
I thought about doing my dash pieces white (to match my truck) but was afraid it might look to ricer for me.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
